Can you recognize the actual errors [message #1749396] |
Tue, 06 December 2016 09:10 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dear all,
Take a look what my project console says,
arm-none-eabi-gcc -mthumb -mfloat-abi=soft -E "-IC:\\Ac6\\SystemWorkbench\\plugins\\fr.ac6.mcu.externaltools.arm-none.win32_1.7.0.201602121829\\tools\\compiler\\bin" "-IC:\\STM32_toolchain\\lib\\gcc" -IC:/STM32_toolchain/common/Drivers/STM32F0xx_HAL_Driver/Inc -IC:/STM32_toolchain/common/Drivers/STM32F0xx_HAL_Driver/Src -O0 -g3 -Wall -fmessage-length=0 -ffunction-sections -c -o "startup\\Src\\stm32f0xx_ll_utils.o" "..\\startup\\Src\\stm32f0xx_ll_utils.c"
..\startup\Src\stm32f0xx_ll_utils.c:39:32: fatal error: stm32f0xx_ll_utils.h: No such file or directory
compilation terminated.
For the project properties setting, kindly take a look on my image file.![http://](http://)
Re: Can you recognize the actual errors [message #1749455 is a reply to message #1749400] |
Wed, 07 December 2016 00:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dear Sir Jonah Graham,
Thank you a lot for taking part in this post.
You have nicely figure out the things and good supporting links.
Besides, SW4STM32 or AC6 I also tried it to mdk-keil and coo-cox.
There was an issue for conflicting compiler and standered file.
An STM expert told me from his experience,
"After realizing that CubeMX did not meet everybody's expectations, the came up with the "Low Level" library.
This "Low Level" lib is part of CubeMX, or a sub-set thereof, and are labelled with this "_ll_" part in their name.
However, in some cases (especially for the STM32F7 I checked), this Low Level lib is nothing but a sorry stub (i.e. unusable fragments).
According to some comments on other threads, it is supposed to be complete for the STM32L4, "with support for other MCUs in progress" - whatever this means."
I will come back soon after getting something new from your guidance.
Hasan
Re: Can you recognize the actual errors [message #1749550 is a reply to message #1749455] |
Thu, 08 December 2016 05:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
At this moment, I find a clue (not sure its a reason)
As you said, "../Inc" must be follow, I saw my Korean WIN OS, might be showing 'W' symbol instead of "../
I have corrected this sign.
This time console says something about output files.
Info: Internal Builder is used for build
arm-none-eabi-gcc -mthumb -mfloat-abi=soft "-TC:\\STM32_toolchain\\Workspace\\project_1\\LinkerScript.ld" -Wl,-Map=output.map -Wl,--gc-sections -lm -o project_1 "src\\rc_new.o" "src\\stm32f0xx_hal.o" "src\\stm32f0xx_hal_msp.o" "src\\stm32f0xx_it.o" "src\\syscalls.o" "startup\\Src\\stm32f0xx_hal.o" "startup\\Src\\stm32f0xx_hal_adc.o" "startup\\Src\\stm32f0xx_hal_adc_ex.o" "startup\\Src\\stm32f0xx_hal_can.o" "startup\\Src\\stm32f0xx_hal_cec.o" "startup\\Src\\stm32f0xx_hal_comp.o" "startup\\Src\\stm32f0xx_hal_cortex.o" "startup\\Src\\stm32f0xx_hal_crc.o" "startup\\Src\\stm32f0xx_hal_crc_ex.o" "startup\\Src\\stm32f0xx_hal_dac.o" "startup\\Src\\stm32f0xx_hal_dac_ex.o" "startup\\Src\\stm32f0xx_hal_dma.o" "startup\\Src\\stm32f0xx_hal_flash.o" "startup\\Src\\stm32f0xx_hal_flash_ex.o" "startup\\Src\\stm32f0xx_hal_gpio.o" "startup\\Src\\stm32f0xx_hal_i2c.o" "startup\\Src\\stm32f0xx_hal_i2c_ex.o" "startup\\Src\\stm32f0xx_hal_i2s.o" "startup\\Src\\stm32f0xx_hal_irda.o" "startup\\Src\\stm32f0xx_hal_iwdg.o" "startup\\Src\\stm32f0xx_hal_msp_template.o" "startup\\Src\\stm32f0xx_hal_pcd.o" "startup\\Src\\stm32f0xx_hal_pcd_ex.o" "startup\\Src\\stm32f0xx_hal_pwr.o" "startup\\Src\\stm32f0xx_hal_pwr_ex.o" "startup\\Src\\stm32f0xx_hal_rcc.o" "startup\\Src\\stm32f0xx_hal_rcc_ex.o" "startup\\Src\\stm32f0xx_hal_rtc.o" "startup\\Src\\stm32f0xx_hal_rtc_ex.o" "startup\\Src\\stm32f0xx_hal_smartcard.o" "startup\\Src\\stm32f0xx_hal_smartcard_ex.o" "startup\\Src\\stm32f0xx_hal_smbus.o" "startup\\Src\\stm32f0xx_hal_spi.o" "startup\\Src\\stm32f0xx_hal_spi_ex.o" "startup\\Src\\stm32f0xx_hal_tim.o" "startup\\Src\\stm32f0xx_hal_tim_ex.o" "startup\\Src\\stm32f0xx_hal_tsc.o" "startup\\Src\\stm32f0xx_hal_uart.o" "startup\\Src\\stm32f0xx_hal_uart_ex.o" "startup\\Src\\stm32f0xx_hal_usart.o" "startup\\Src\\stm32f0xx_hal_wwdg.o" "startup\\Src\\stm32f0xx_ll_adc.o" "startup\\Src\\stm32f0xx_ll_comp.o" "startup\\Src\\stm32f0xx_ll_crc.o" "startup\\Src\\stm32f0xx_ll_crs.o" "startup\\Src\\stm32f0xx_ll_dac.o" "startup\\Src\\stm32f0xx_ll_dma.o" "startup\\Src\\stm32f0xx_ll_exti.o" "startup\\Src\\stm32f0xx_ll_gpio.o" "startup\\Src\\stm32f0xx_ll_i2c.o" "startup\\Src\\stm32f0xx_ll_pwr.o" "startup\\Src\\stm32f0xx_ll_rcc.o" "startup\\Src\\stm32f0xx_ll_rtc.o" "startup\\Src\\stm32f0xx_ll_spi.o" "startup\\Src\\stm32f0xx_ll_tim.o" "startup\\Src\\stm32f0xx_ll_usart.o" "startup\\Src\\stm32f0xx_ll_utils.o" "startup\\startup_stm32.o" "startup\\sysmem.o"
src\rc_new.o: file not recognized: File format not recognized
collect2.exe: error: ld returned 1 exit status
Whats about, "file not recognized: File format not recognized"?
Re: Can you recognize the actual errors [message #1749554 is a reply to message #1749551] |
Thu, 08 December 2016 06:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dear Sir David,
Thanks a lot for your prompt reply.
Could you kindly tell me/ give me manual reference to deal with "attach the build log or at least the part where the object file is produced :.
Are you talking about C:\STM32_toolchain\Workspace\.metadata\.plugins\org.eclipse.cdt.ui\project_1.build.log adress to connect some where?
Hasan
[Updated on: Thu, 08 December 2016 06:21] Report message to a moderator
Re: Can you recognize the actual errors [message #1749640 is a reply to message #1749564] |
Fri, 09 December 2016 01:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dear Sir David,
I misunderstand what you ask me to do.
Quote:F and only IF cleaning then rebuilding doesn't work then post the build log here as an attachment.
Now confusion is cleared.
I did clean and rebuild, nothing changes.
Take a look the build.log file in this attachment.
Re: Can you recognize the actual errors [message #1749644 is a reply to message #1749643] |
Fri, 09 December 2016 04:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dear Sir David,
May be my knowledge doesn't get you fully, because I am newcomer here.
What do you mean by ,
Quote:If cleaning the project doesn't delete all of the object files then you will have to do so by hand.
Do you want me to delete these files,
![http://](http://)
Following your idea , I did clean and rebuild again.
That build log file contains,
13:18:51 **** Incremental Build of configuration Debug for project project_1 ****
13:18:51 Build Finished (took 77ms)
[Updated on: Fri, 09 December 2016 04:20] Report message to a moderator
Re: Can you recognize the actual errors [message #1749645 is a reply to message #1749644] |
Fri, 09 December 2016 05:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
David Vavra![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=davavra%40verizon.net) Messages: 1426 Registered: October 2012 |
No you didn't clean the project. A clean deletes all of the object files.
A subsequent build would then rebuild all of the files.
The build log will start with "**** Build of configuration Debug for project ..."
The log you are showing starts with "**** Incremental Build of configuration Debug for project ..."
Not sure what you actually did but,
To clean the project: Right click on the project name in the Project Explorer. Select Clean Project
To build: Right click on the project name in the Project Explorer. Select Build Project
There are multiple ways to do this but the above are IMO the simplest.
You appear to be new to code development as you don't seem to understand the fundamentals. I suggest you Google some tutorials on how to compile and link programs using GCC and MAKE. Eclipse is using those as external tools and the design of Eclipse assumes you know how to use them outside of Eclipse.
This forum is for dealing with issues involving CDT. The current problem you are having likely has nothing to do with CDT but there is still the off-chance you have set something wrong while using Eclipse. You shouldn't expect much help here beyond Eclipse usage. Issues with your specific version of gcc and programming of the device you are using would be better answered at the place where you got them.
[Updated on: Fri, 09 December 2016 05:24] Report message to a moderator
Re: Can you recognize the actual errors [message #1749647 is a reply to message #1749645] |
Fri, 09 December 2016 05:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dear Sir,
No you didn't clean the project. A clean deletes all of the object files.Quote:
This would have some technical common problem, did you see my project tree ?
In Debug folder all output files are exists, the question is does the logfile changes rightly after clean the project at C:\STM32_toolchain\Workspace\.metadata\.plugins\org.eclipse.cdt.ui\project_1.build.log/
Quote:To clean the project: Right click on the project name in the Project Explorer. Select Clean Project
I did same what you have explained !
Quote:I suggest you Google some tutorials on how to compile and link programs using GCC and MAKE.
Is there any required setting in Windows>Preferences> makefile projects?
I am connected with, http://www.openstm32.org/, https://community.st.com/,https://launchpad.net/gcc-arm-embedded, forums, these are not a problem from GCC or STM device.
Re: Can you recognize the actual errors [message #1749661 is a reply to message #1749647] |
Fri, 09 December 2016 09:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Quite frankly everything you just posted is confusing.
You seem to be saying that Clean Project did not delete the object files.
If so then there is a bug in the makefile or it doesn't have a clean target.
This is quite abnormal if Eclipse built the makefile.
I'm not sure I can help you further.
Run a clean then post the resultant build log.
Perhaps someone more familiar with how CDT creates makefiles can help or maybe a bug report needs to be filed.
[Updated on: Fri, 09 December 2016 09:57] Report message to a moderator
Re: Can you recognize the actual errors [message #1749772 is a reply to message #1749661] |
Mon, 12 December 2016 04:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
]Dear Sir Vavra,
After deleting the debug folder I did clean the project in this way,
Project>clean ...the window came ,
![index.php/fa/27830/0/](index.php/fa/27830/0/)
One very interesting thing happened,
After clean Debug folder appears in project tree !
Build log file says,
11:51:32 **** Incremental Build of configuration Debug for project project_1 ****
arm-none-eabi-gcc -mthumb -mfloat-abi=soft "-TC:\\STM32_toolchain\\Workspace\\project_1\\LinkerScript.ld" -Wl,-Map=output.map -Wl,--gc-sections -lm -o project_1 "src\\main.o" "src\\stm32f0xx_hal.o" "src\\stm32f0xx_hal_msp.o" "src\\stm32f0xx_it.o" "src\\syscalls.o" "startup\\Src\\stm32f0xx_hal.o" "startup\\Src\\stm32f0xx_hal_adc.o" "startup\\Src\\stm32f0xx_hal_adc_ex.o" "startup\\Src\\stm32f0xx_hal_can.o" "startup\\Src\\stm32f0xx_hal_cec.o" "startup\\Src\\stm32f0xx_hal_comp.o" "startup\\Src\\stm32f0xx_hal_cortex.o" "startup\\Src\\stm32f0xx_hal_crc.o" "startup\\Src\\stm32f0xx_hal_crc_ex.o" "startup\\Src\\stm32f0xx_hal_dac.o" "startup\\Src\\stm32f0xx_hal_dac_ex.o" "startup\\Src\\stm32f0xx_hal_dma.o" "startup\\Src\\stm32f0xx_hal_flash.o" "startup\\Src\\stm32f0xx_hal_flash_ex.o" "startup\\Src\\stm32f0xx_hal_gpio.o" "startup\\Src\\stm32f0xx_hal_i2c.o" "startup\\Src\\stm32f0xx_hal_i2c_ex.o" "startup\\Src\\stm32f0xx_hal_i2s.o" "startup\\Src\\stm32f0xx_hal_irda.o" "startup\\Src\\stm32f0xx_hal_iwdg.o" "startup\\Src\\stm32f0xx_hal_msp_template.o" "startup\\Src\\stm32f0xx_hal_pcd.o" "startup\\Src\\stm32f0xx_hal_pcd_ex.o" "startup\\Src\\stm32f0xx_hal_pwr.o" "startup\\Src\\stm32f0xx_hal_pwr_ex.o" "startup\\Src\\stm32f0xx_hal_rcc.o" "startup\\Src\\stm32f0xx_hal_rcc_ex.o" "startup\\Src\\stm32f0xx_hal_rtc.o" "startup\\Src\\stm32f0xx_hal_rtc_ex.o" "startup\\Src\\stm32f0xx_hal_smartcard.o" "startup\\Src\\stm32f0xx_hal_smartcard_ex.o" "startup\\Src\\stm32f0xx_hal_smbus.o" "startup\\Src\\stm32f0xx_hal_spi.o" "startup\\Src\\stm32f0xx_hal_spi_ex.o" "startup\\Src\\stm32f0xx_hal_tim.o" "startup\\Src\\stm32f0xx_hal_tim_ex.o" "startup\\Src\\stm32f0xx_hal_tsc.o" "startup\\Src\\stm32f0xx_hal_uart.o" "startup\\Src\\stm32f0xx_hal_uart_ex.o" "startup\\Src\\stm32f0xx_hal_usart.o" "startup\\Src\\stm32f0xx_hal_wwdg.o" "startup\\Src\\stm32f0xx_ll_adc.o" "startup\\Src\\stm32f0xx_ll_comp.o" "startup\\Src\\stm32f0xx_ll_crc.o" "startup\\Src\\stm32f0xx_ll_crs.o" "startup\\Src\\stm32f0xx_ll_dac.o" "startup\\Src\\stm32f0xx_ll_dma.o" "startup\\Src\\stm32f0xx_ll_exti.o" "startup\\Src\\stm32f0xx_ll_gpio.o" "startup\\Src\\stm32f0xx_ll_i2c.o" "startup\\Src\\stm32f0xx_ll_pwr.o" "startup\\Src\\stm32f0xx_ll_rcc.o" "startup\\Src\\stm32f0xx_ll_rtc.o" "startup\\Src\\stm32f0xx_ll_spi.o" "startup\\Src\\stm32f0xx_ll_tim.o" "startup\\Src\\stm32f0xx_ll_usart.o" "startup\\Src\\stm32f0xx_ll_utils.o" "startup\\startup_stm32.o" "startup\\sysmem.o"
src\main.o: file not recognized: File format not recognized
11:51:32 Build Finished (took 81ms)
[Updated on: Mon, 12 December 2016 04:27] Report message to a moderator
Re: Can you recognize the actual errors [message #1749773 is a reply to message #1749772] |
Mon, 12 December 2016 04:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Then delete the object files by hand. In fact, you should be able to delete the entire Debug folder as Jonah suggested. It will be recreated at the next build.
EDIT:
I notice that a different object file (src\main.o) is giving you problems than before (src\rc_new.o). Something has gone terribly wrong. Delete the entire Debug folder then rebuild and post the build log.
Also, I just noticed: "Internal Builder is used for build". Not sure what effect it has compared to using make. But first things first.
[Updated on: Mon, 12 December 2016 05:08] Report message to a moderator
Re: Can you recognize the actual errors [message #1749792 is a reply to message #1749776] |
Mon, 12 December 2016 11:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No object files are being produced because you have the -E option in the compile command line.
This option says to output only the preprocessor results.
The output files have a *.o extent but are actually text files instead of object files.
https://gcc.gnu.org/onlinedocs/gcc-4.1.0/gcc/Preprocessor-Options.html#Preprocessor-Options
Remove this option.
You have -IC:/STM32_toolchain/Workspace/.metadata/.plugins/org.eclipse.cdt.ui/project_1.build.log
which doesn't actually hurt anything but is completely unnecessary.
You are also redefining some macros to null text
e.g., #define KEY_SW1_Pin GPIO_PIN_5 ==> #define KEY_SW1_Pin
I can't say if this will cause problems.
If you really meant to do this you should use #undef <macro> instead.
EDIT:
It's curious that you couldn't clean the project but at least you have the workaround.
You will need to do this once again after you have removed the -E option.
[Updated on: Mon, 12 December 2016 12:08] Report message to a moderator
Re: Can you recognize the actual errors [message #1749830 is a reply to message #1749792] |
Tue, 13 December 2016 02:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dear Sir,
No object files are being produced because you have the -E option in the compile command line.This option says to output only the preprocessor results.
I have removed -E options, keep is this way.
![index.php/fa/27845/0/](index.php/fa/27845/0/)
Quote: If you really meant to do this you should use #undef <macro> instead.
Yes , I will.
Quote:You will need to do this once again after you have removed the -E option
Kindly take a look log file after removing -E , deleting obj files from debug folder .
Re: Can you recognize the actual errors [message #1749843 is a reply to message #1749841] |
Tue, 13 December 2016 08:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thank you sir Graham,
Quote: Please link to me the forum entry that says to use -E so I can add clarifying comments so that no one else falls down that trap in the future.
I will be happy to connect with you anywhere.
What I did now , is just went your profile click add buddy list.
If you want me to make a new thread, I will for sure.
Let me know where should I have to post.
Hasan
Re: Can you recognize the actual errors [message #1749867 is a reply to message #1749843] |
Tue, 13 December 2016 11:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Mubdiul,
You asked about the "no such parameter" error at least once before.
https://www.eclipse.org/forums/index.php?t=msg&th=1082306&goto=1746969&#msg_1746969
The error message is an indication that the compiler is confused.
It is most probably caused by the errors preceding it.
Resolve those and the rest will likely go away.
My original reply still stands: https://www.eclipse.org/forums/index.php?t=msg&th=1082306&goto=1746983&#msg_1746983
However, you didn't believe me then and probably still don't.
The first error in the log you last posted is shown below.
My guess is the line was supposed to be a comment
If it should be and/or why it is not is for you to determine.
Fix it before you do anything else (likely a missing "/*" someplace).
Fixing this is off-topic here.
This forum is for fixing CDT related issues and clearly this is not one.
You may find help by using other forums but, generally, none of them will assist in debugging or correcting your code because you are essentially asking for free, very time-consuming consultation.
In file included from C:/STM32_toolchain/Workspace/project_1/startup/Inc/stm32f0xx_hal.h:48:0,
from ..\startup\Src\stm32f0xx_hal_flash_ex.c:61:
C:/STM32_toolchain/common/Drivers/STM32F0xx_HAL_Driver/Inc/stm32f0xx_hal_conf.h:3:5: error: stray '@' in program
* @file stm32f0xx_hal_conf.h
[Updated on: Tue, 13 December 2016 13:04] Report message to a moderator
Re: Can you recognize the actual errors [message #1749927 is a reply to message #1749867] |
Wed, 14 December 2016 01:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
David,
I did not tell you that I wont believe your instruction.
Your reference post is mine , but I was working with different set of project.
I do accept your suggestion, but seems these build errors are both CDT and the errors mentioned you last post.
This one is a reason indeed.
Re: Can you recognize the actual errors [message #1749928 is a reply to message #1749916] |
Wed, 14 December 2016 01:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Voipio,
I beg pardon for my ignorance !
Kindly explain
This is the another example of the quality of the chip-vendor-provided code. Obviously it is a broken Doxygen comment in the beginning of the module. It should be: /** @file stm320fxx_hal_conf.h */
I also thought, its from chip-vendor code.
As far as I remember during project properties setting , I avoid Doxygen !
