| Re: Random Errors while build file [message #1747053 is a reply to message #1746983] |
Tue, 08 November 2016 19:32  |
Dear Sir Devid,
Thank you once again.
Even I worked MCU coding for 2 years, it looks things are going much complex if you want to do something new. Still I am newcomer in this area!
My company gave me a reference code to develop, It has a main file with hundreds of supporting HAL header and c.
APIs, Headers,state machine files are exists in Project branch, but why the compiler showing errors in H files of driver ?
Looking at your C code structure related reason, yes I found some style of C coding in CMSIS h files is different.
I tried to build this file in COOCOX, its fine in errors but build fails due to,
C:\Users\swend95_하산\Desktop\Old_rice_cooker\Source_bak\common\Drivers\CMSIS\Device\ST\STM32F0xx\Source\Templates\gcc does not exist.
It might tell something about s files or directory that I cant solve.
In ecilipse what should I do now?
1. CDT does not showing errors of my main files, there was a return type problem, I solved it.
3. I think compiler is compiling all files listed in project branch , do you want me to remove some of the files from project folder, is it repeating again as I include paths from C driver?
4. Is there any setting for which only compile my c file?
5. Do you believe, updated version of Java/gcc/Eclipse is needed ?
I am using this HAL driver STM32Cube_FW_F0_V1.6.0 downloaded from STM website.
Hope you will give me some good suggestions.
HASAN
FUDForum. Page generated in 0.08413 seconds
