Reusing variables across setups [message #1739891] |
Fri, 05 August 2016 13:07 |
Christian Wolff Messages: 18 Registered: April 2016 |
I have multiple setups which (should) use the same variable, each one defines its own variable task with the same variable name "myvar". If I select multiple setups in the installer I am prompted to input the variable multiple times. How would I need to declare these variable tasks so that a user is only asked once and the variable is then reused? If I dont declare a variable task at all it seems I only get asked once, but if I add another project setup to an existing installation at a later time (which also uses this variable) another window pops up asking me for the same variable again.
I think I am just confused about the corrcet usage of variables and unfortunately the documentation (which is already pretty detailed for variables) did not help me much either. Did I miss something?
Thanks in advance!
Christian
EDIT: Apparently I did miss it I now define my variable tasks in the projects catalog and it works. However they are only asked when Eclipse first starts (not before the installation) but I guess since they are only first used at this point in time that this is something I have to live with?
[Updated on: Mon, 08 August 2016 11:09] Report message to a moderator
Re: Reusing variables across setups [message #1742040 is a reply to message #1739891] |
Fri, 05 August 2016 13:30 |
Ed Merks Messages: 33236 Registered: July 2009 |
Christian,
Comments below.
On 05.08.2016 15:07, Christian Wolff wrote:
Yes, generally each stream is processed separately with variables all
expanded before they are composed into a single peformer. So generally
one doesn't need to worry if some other setup happens to use the same
variable name, perhaps for a totally different purpose.
I think adding this annotation would do the trick:
<base:Annotation
xmi:version="2.0"
xmlns:base="http://www.eclipse.org/oomph/base/1.0"
source="http://www.eclipse.org/oomph/setup/GlobalVariable"/>
This should force the Variables page to create a single prompted field
for the variable's value.
(Did you know you can copy full XMI text like the above and paste it
into a setup task?
Yes, normally the scope of the variable affects its uniqueness, but an
undeclared variable has no scope (isn't contained by anything).
Yes, value of the variable isn't stored.
The secret magical annotation. :-P
> Thanks in advance!
> Christian
Ed Merks
FUDForum. Page generated in 0.02832 seconds
