Re: Jubula 8.3 Standalone [message #1740615 is a reply to message #1740286] |
Tue, 16 August 2016 09:15 |
Hello Fatih,
the problem with not being able to start the autagent.exe is a user permissions problem on Windows. You most likely installed Jubula with administrator rights into a C:\Program Files\ subfolder. Now the problem with that is, that the autagent.exe wants to create some local configuration files during execution but is not being able to do so when starting the autagent.exe without the necessary (administrator) rights. The autagent.exe should however start and run perfectly fine when starting with administrator rights or if you install Jubula into a different folder that does not require administrator rights.
Unfortunately I were not able to reproduce your JaCoCo problem. Could you please try to run Jubula with administrator rights. From the error log it seems that JaCoCo tries to access a file that also is located in a C:\Program Files\ subfolder and it might not have the necessary rights to do so.
Kevin
FUDForum. Page generated in 0.03222 seconds
