Re: Setup ESH development environment failed [message #1737543 is a reply to message #1737540] |
Sat, 09 July 2016 17:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dale Angus![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=daleangus%40hotmail.com) Messages: 9 Registered: July 2016 |
Linux installation:
I ran mvn under ~/smarthome-master/git/smarthome
Looks like I missed an argument. Which lifecycle to use?
[ERROR] No goals have been specified for this build. You must specify a valid lifecycle phase or a goal in the format <plugin-prefix>:<goal> or <plugin-group-id>:<plugin-artifact-id>[:<plugin-version>]:<goal>. Available lifecycle phases are: validate, initialize, generate-sources, process-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-resources, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, post-integration-test, verify, install, deploy, pre-clean, clean, post-clean, pre-site, site, post-site, site-deploy. -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/NoGoalSpecifiedException
Re: Setup ESH development environment failed [message #1737544 is a reply to message #1737540] |
Sat, 09 July 2016 17:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I cannot reproduce it. If I follow all steps there are 0 errors remaining.
Here a short summary of what I have done / the results:
* Using Eclipe Installer "1.4.0 Build 2444"
Product
* Eclipse IDE for Java Developers
* Product Version: Latest Release (Neon)
* Java 1.8 + VM: /usr/bin/jvm/oracle-jdk-bin-1.8
Project
* Eclipse Projects, SmartHome, Runtime and Designer
After step 7
* Problems: 299 errors, 1,620 warnings, 0 others (Filtter matches 200 of 1919 items)
After step 8 (after the last step "Launch Generate All Models" succeeded")
* Problems: 95 errors, 1,949 warnings, 0 others (Filtter matches 195 of 2044 items)
After step 9 (clean all with a rebuild)
* Problems: 0 errors, 1,635 warnings, 0 others (Filtter matches 100 of 1947 items)
Re: Setup ESH development environment failed [message #1737547 is a reply to message #1737545] |
Sat, 09 July 2016 17:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
OK. I'll keep trying. So far it's doing something with node and npm install (both Windows and Linux)
I saw this
[INFO] Installed node locally.
[INFO] Installing npm version 3.3.12
[INFO] Downloading http://registry.npmjs.org/npm/-/npm-3.3.12.tgz to C:\Users\d7qm322\.m2\repository\com\github\eirslett\npm\3.3.12\npm-3.3.12.tar.gz
[INFO] No proxies configured
[INFO] No proxy was configured, downloading directly
[INFO] Unpacking C:\Users\d7qm322\.m2\repository\com\github\eirslett\npm\3.3.12\npm-3.3.12.tar.gz into C:\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper\node\node_modules
[INFO] Installed npm locally.
[INFO]
[INFO] --- frontend-maven-plugin:1.0:npm (npm install) @ org.eclipse.smarthome.ui.paper ---
[INFO] Running 'npm install' in C:\smarthome-master\git\smarthome\extensions\ui\org.eclipse.smarthome.ui.paper
[WARNING] npm WARN engine bootstrap@3.3.2: wanted: {"node":"~0.10.1"} (current: {"node":"5.4.0","npm":"3.3.12"})
[WARNING] npm WARN install Couldn't install optional dependency: Unsupported
[Updated on: Sat, 09 July 2016 17:46] Report message to a moderator
Re: Setup ESH development environment failed [message #1737553 is a reply to message #1737551] |
Sat, 09 July 2016 18:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Dale Angus wrote on Sat, 09 July 2016 18:42And so I did. And SUCCESS!
Sounds good.
The npm stuff is for the Paper UI (its dependencies). It downloads a lot of stuff, so the time depends on your internet connection and the speed that is provided by the servers that hosting the third party stuff.
Happy coding.
FUDForum. Page generated in 0.05814 seconds
