Home » Modeling » TMF (Xtext) » Cyclic linking detected when building in maven(Error occurs only when building with xtext-maven-plugin )
Cyclic linking detected when building in maven [message #1736601] Thu, 30 June 2016 10:20 Go to next message
I am stuck. My DSL provides a scoping which works nice in Eclipse, but when I try to build the project with maven it fails with:
DefaultComponentFeatureDotRef.right->DefaultComponentFeatureDotRef.right
What is the difference between the maven build and the Eclipse build?
Why does it fails with maven?
Any help, hint welcome.
Re: Cyclic linking detected when building in maven [message #1736605 is a reply to message #1736601] Thu, 30 June 2016 10:25 Go to previous messageGo to next message
there should not be any difference. can you come up with a small reproducing example?
the error says basically you have a cycle in scoping / access scope at wrong places e.g. nameprovider
Re: Cyclic linking detected when building in maven [message #1736739 is a reply to message #1736605] Fri, 01 July 2016 08:03 Go to previous messageGo to next message
Sorry but it took me a long time to strip all the unnecessary parts.
Hope the project works for you.
The problem still exists in eclipse the project builds correctly but maven fails.
Re: Cyclic linking detected when building in maven [message #1736908 is a reply to message #1736739] Mon, 04 July 2016 06:42 Go to previous messageGo to next message
I have solved the problem for now.
It seems that the late initialization within the Inferrer works different in maven build.
When I put the initialization into the toClass() method everything seems to be ok now.
Hope it stays this way.
Re: Cyclic linking detected when building in maven [message #1736909 is a reply to message #1736908] Mon, 04 July 2016 06:45 Go to previous messageGo to next message
can you tell what your change exactly was?
Re: Cyclic linking detected when building in maven [message #1736926 is a reply to message #1736909] Mon, 04 July 2016 08:02 Go to previous messageGo to next message
   			acceptor.accept(comp.toClass(className))[
   				val start = System.currentTimeMillis
   				lateInitializationSetupComponent(it, comp.name, comp.toJvmType, comp.content)
				static = false
				printDuration("create Component "+comp.name+": ", start)
to
   			acceptor.accept(comp.toClass(className, [
				static = false
But this raises other issues, but I hope I can cope with them.
Re: Cyclic linking detected when building in maven [message #1736934 is a reply to message #1736926] Mon, 04 July 2016 08:30 Go to previous messageGo to next message
it should work the first way. (depending on what you are actually doing inside the method lateInitializationSetupComponent
Re: Cyclic linking detected when building in maven [message #1736963 is a reply to message #1736934] Mon, 04 July 2016 12:47 Go to previous messageGo to next message
here is the cycle and a potential workaround
at om.lutte.cyclicLinking.Util.getDefaultTypeByRef(Util.java:301)
at om.lutte.cyclicLinking.Util.toJvmType(Util.java:230)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lambda$6(LinkJvmModelInferrer.java:331)
at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.createSetupTriggerPoint(LinkJvmModelInferrer.java:375)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lambda$5(LinkJvmModelInferrer.java:320)
at java.lang.Iterable.forEach(Iterable.java:75)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lateInitializationSetupComponent(LinkJvmModelInferrer.java:323)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lambda$3(LinkJvmModelInferrer.java:291)
at org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator$1.run(JvmModelAssociator.java:397)
at org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator.installDerivedState(JvmModelAssociator.java:407)
at org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:242)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getContents(BatchLinkableResource.java:148)
at org.eclipse.emf.ecore.util.EcoreUtil.getAllContents(EcoreUtil.java:1176)
at org.eclipse.xtext.xbase.scoping.XImportSectionNamespaceScopeProvider$3.iterator(XImportSectionNamespaceScopeProvider.java:283)
at com.google.common.collect.Iterables$8.iterator(Iterables.java:713)
at com.google.common.collect.Iterables$6.iterator(Iterables.java:589)
at org.eclipse.xtext.scoping.impl.MultimapBasedSelectable.setExportedObjects(MultimapBasedSelectable.java:106)
at org.eclipse.xtext.scoping.impl.MultimapBasedSelectable.<init>(MultimapBasedSelectable.java:36)
at org.eclipse.xtext.xbase.scoping.XImportSectionNamespaceScopeProvider.internalGetAllDescriptions(XImportSectionNamespaceScopeProvider.java:287)
at org.eclipse.xtext.xbase.scoping.XImportSectionNamespaceScopeProvider$2.get(XImportSectionNamespaceScopeProvider.java:274)
at org.eclipse.xtext.xbase.scoping.XImportSectionNamespaceScopeProvider$2.get(XImportSectionNamespaceScopeProvider.java:1)
at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:77)
at org.eclipse.xtext.xbase.scoping.XImportSectionNamespaceScopeProvider.getAllDescriptions(XImportSectionNamespaceScopeProvider.java:271)
at org.eclipse.xtext.xbase.scoping.XImportSectionNamespaceScopeProvider.getGlobalScope(XImportSectionNamespaceScopeProvider.java:89)
at org.eclipse.xtext.xbase.scoping.XImportSectionNamespaceScopeProvider.getScope(XImportSectionNamespaceScopeProvider.java:82)
at om.lutte.cyclicLinking.scoping.LinkScopeProviderDelegate.getScope(LinkScopeProviderDelegate.java:107)
at org.eclipse.xtext.xbase.scoping.batch.XbaseBatchScopeProvider.delegateGetScope(XbaseBatchScopeProvider.java:63)
at org.eclipse.xtext.xbase.scoping.batch.XbaseBatchScopeProvider.getScope(XbaseBatchScopeProvider.java:107)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getScope(DefaultLinkingService.java:59)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:119)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:247)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getEObject(BatchLinkableResource.java:119)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:199)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:259)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477)
at om.lutte.cyclicLinking.link.impl.DefaultComponentFeatureRefImpl.getFeature(DefaultComponentFeatureRefImpl.java:73)
at om.lutte.cyclicLinking.Util.getDefaultTypeByRef(Util.java:303)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lambda$8(LinkJvmModelInferrer.java:501)
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.initializeSafely(JvmTypesBuilder.java:207)
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toClass(JvmTypesBuilder.java:385)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.createTpPiece(LinkJvmModelInferrer.java:523)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lambda$15(LinkJvmModelInferrer.java:460)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lambda$7(LinkJvmModelInferrer.java:463)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.createSetupPiece(LinkJvmModelInferrer.java:490)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lambda$11(LinkJvmModelInferrer.java:119)
at om.lutte.cyclicLinking.jvmmodel.LinkJvmModelInferrer.lambda$0(LinkJvmModelInferrer.java:122)
at org.eclipse.xtext.builder.standalone.StandaloneBuilder.launch(StandaloneBuilder.java:292)
at org.eclipse.xtext.maven.XtextGenerator.internalExecute(XtextGenerator.java:165)
override getScope(EObject context, EReference reference) {
var IScope retval = null
// println("<getScope> context: "+context)
// println("<getScope> reference: "+reference.name+" / "+reference)
val superScope = if (reference == LinkPackage.Literals.DEFAULT_COMPONENT_FEATURE_REF__FEATURE) IScope.NULLSCOPE else super.getScope(context, reference)
if (retval == null)
retval = linkScopeDefaultTypes.getScope(context, reference, superScope)
if (retval == null)
retval = linkScopeTopologyFeature.getScope(context, reference, superScope)
if (retval == null)
superScope
} else
retval
Re: Cyclic linking detected when building in maven [message #1737441 is a reply to message #1736963] Fri, 08 July 2016 05:46 Go to previous messageGo to next message
Thank you for the replay, I found an other solution. It looks different, but my real dsl is much more complex.
I had to override org.eclipse.xtext.xbase.resource.BatchLinkableResource as in my case the cycle seems to be the normal behavior.
I am doing something like this
File one contains:
defaultObject = new XYZObject (xyzAttribute1 = "x", xyzAttribute2="x2", ...)
File two contains:
aNewObject = extends defaultObject  (xyzA1 = "x", xyzAttribute2="x2", ...)
To create the sope for xyzA1 I need to find the JvmType of XYZObject. When I try to resolve the type of XYZObject the whole model of "File one" seems to be parsed, and this causes the cycle. At the second call the model of "File one" has been parsed, so the cycle is broken.(At least this is my guess)
	val counter = new HashMap<Triple<EObject, EReference, INode>, AtomicInteger>()
	override protected handleCyclicResolution(Triple<EObject, EReference, INode> triple) throws AssertionError {
		try{
			val calls = incrementAndGetCounter(triple)
			if (calls > 3)
				super.handleCyclicResolution(triple)
			} else
				val node = triple.third
				val message = "Cyclic linking detected " +calls+": "+ getReferences(triple, resolving)+"\n"
					+"       "+getReferencesNode(triple, resolving)
				println(message)
//					new Exception(message).printStackTrace
				val linkedObjects = getLinkingService().getLinkedObjects(
					triple.first,
					triple.second,
					node);
				linkedObjects.head
		} finally
			decrepementAndGetCounter(triple)
	def int incrementAndGetCounter (Triple<EObject, EReference, INode> triple)
		val c = counter.get(triple)
		if (c == null)
			counter.put(triple, new AtomicInteger(1))
			1
		} else
			c.incrementAndGet
	def int decrepementAndGetCounter (Triple<EObject, EReference, INode> triple)
		if (c == null)
			counter.put(triple, new AtomicInteger(-1))
			(-1)
		} else
			c.decrementAndGet
	def protected String getReferencesNode(Triple<EObject, EReference, INode> triple,
			LinkedHashSet<Triple<EObject, EReference, INode>> resolving2) {
		val buffer = new StringBuffer();
		var found = false;
		for (Triple<EObject, EReference, INode> triple2 : resolving2) {
			found = found || triple2.equals(triple);
			if (found)
				buffer.append(getQualifiedNodeName(triple2.third)).append("->");
		buffer.append(getQualifiedNodeName(triple.third));
		return buffer.toString();
	def private String getQualifiedNodeName(INode node) {
		return node.text;
In my case the cycle only occurred once.
Cyclic linking detected 1: EmuContentRef.emuContent->Parameter.parameterFeature->EmuContentRef.emuContent
       chuteTp->unitId->chuteTp
Cyclic linking detected 1: JvmParameterizedTypeReference.type->Parameter.parameterFeature->JvmParameterizedTypeReference.type
        VarioscNodeComponent->nodeIdVariosc-> VarioscNodeComponent
       defaultTp->name->defaultTp
I am fine with this solution. And for now it works.
But it does not answers the question, why it is behaving different in Eclipse, than in Maven. (But for now I am happy Smile )
Re: Cyclic linking detected when building in maven [message #1737443 is a reply to message #1737441] Fri, 08 July 2016 05:49 Go to previous message
i actually dont know
Previous Topic:can we have two different xtext grammar files from single xtext project?
Next Topic:Convert xtext code to JavaScript
Current Time: Mon Oct 27 17:40:58 EDT 2025
Powered by FUDForum. Page generated in 0.11205 seconds
