Home » Eclipse Projects » WindowBuilder » Is there some WB 1.9.0 / Neon (4.6) integration developer preview
Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1729617] Sat, 16 April 2016 07:02 Go to next message
Vincenzo Caselli is currently offline Vincenzo CaselliFriend
Hi Eric,
is there some WB 1.9.0 or any other Neon (4.6) integration nightly update site available, to be tested with Neon (M6+) ?
Thank you very much
Vincenzo
Re: Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1733405 is a reply to message #1729617] Fri, 27 May 2016 09:36 Go to previous messageGo to next message
Abel Hegedus is currently offline Abel HegedusFriend
There is still no WB version that supports Neon. It seems that Lars Vogel has stepped up to help in getting a new version with a signed build done:
https://www.eclipse.org/forums/index.php/t/1076702/
https://bugs.eclipse.org/bugs/show_bug.cgi?id=481842
Thanks, Lars!
Re: Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1733482 is a reply to message #1733405] Sat, 28 May 2016 05:17 Go to previous messageGo to next message
Hi Abel,
indeed I was aware of the willing of Lars, but I didn't see the answer from Eric as of
https://www.eclipse.org/forums/index.php?t=msg&th=1076702&goto=1732090&#msg_1732090
Wonderful!
Great Lars!
Re: Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1735412 is a reply to message #1729617] Sat, 18 June 2016 17:07 Go to previous messageGo to next message
Daniel Mising name is currently offline Daniel Mising nameFriend
Member
Hi all,
in this post Lars describes how to get Windowbuilder for your Neon.
http://blog.vogella.com/2016/06/14/helping-windowbuilder/
Soon™ there might also exist an online updatesite. For now you have to build and install it from your local harddrive.
Re: Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1736197 is a reply to message #1729617] Mon, 27 June 2016 12:47 Go to previous messageGo to next message
Christoph Zauner is currently offline Christoph ZaunerFriend
Till there is an official WindowBuilder P2 update site for Eclipse Neon you can use mine at https://dl.bintray.com/zaunerc/p2/org.eclipse.windowbuilder.p2_site/latest/. I have provided further background information over here.
Re: Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1736852 is a reply to message #1736197] Sun, 03 July 2016 10:03 Go to previous messageGo to next message
David Garratt is currently offline David GarrattFriend
Member
I am very pleased and grateful that you have provided a Neon version of WindowBuilder Pro. If I setup Eclipse to use that for now is it safe/wise to change the url to the official release when it's made available ?
Who maintains the WindowBuilder Pro project now ?
Dave
Re: Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1738756 is a reply to message #1736852] Sat, 23 July 2016 03:02 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric ClaybergFriend
The new WB update site for Neon can be found here:
http://download.eclipse.org/windowbuilder/WB/integration/4.6/
Thank you Lars, Frederic, and Patrik!!
Re: Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1738763 is a reply to message #1738756] Sat, 23 July 2016 10:41 Go to previous messageGo to next message
Wow, great!
Thank you all!!
Now WB can re-join Eclipse Neon train and be re-included in RCP/RAP & Java package, reverting these:
http://git.eclipse.org/c/epp/org.eclipse.epp.packages.git/commit/?id=23ad1d281727b746c225e7abbdfefd1d4045e53b
http://git.eclipse.org/c/epp/org.eclipse.epp.packages.git/commit/?id=b36396c90c74ac2ab912bbe8c557b22ea4ea4b01
Please guys, don't forget to announce the Neon.1 re-join, as David Williams asked here
https://dev.eclipse.org/mhonarc/lists/cross-project-issues-dev/msg13368.html
as well as ensure the reverting of commits above.
Thank you all again!
Vincenzo
icon5.gif  Re: Is there some WB 1.9.0 / Neon (4.6) integration developer preview [message #1739165 is a reply to message #1736852] Thu, 28 July 2016 01:48 Go to previous message
Chupocro cc is currently offline Chupocro ccFriend
Dave Garratt wrote on Sun, 03 July 2016 12:03
I would like to know the same. What will happen after 22nd September?
a) Official WindowBuilder will be marked as 'not installed' so we'll have to first uninstall the temporary release and then install the official one.
b) The official release will recognize WindowBuider as already 'installed' and the temporary release will be updated to the official build.
c) Something else.
Chupo_cro
Previous Topic:WindowBuilder DesignerException 1100
Next Topic:Convert WindowBuilder to Tycho
Current Time: Wed Feb 05 10:43:48 GMT 2025
Powered by FUDForum. Page generated in 0.03999 seconds
