Home » Archived » Package Drone » Difficulty setting up an example p2 repository
Difficulty setting up an example p2 repository [message #1734309] |
Tue, 07 June 2016 00:20  |
I've followed the recipe text to create this sample channel (big thanks for providing the easy openshift setup) and I've uploaded my Tycho build to it. Eclipse successfully sees the update site, but it can't download any of the artifacts:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.modeling, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.mdht.cda.xml.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.cda.xml.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.dita.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.dita.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.emf.runtime,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.emf.runtime.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.transform.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.transform.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ant,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ant.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.dita,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.dita.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.resources,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.resources.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.validation,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.validation.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.edit,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.edit.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.datatypes,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.datatypes.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.rim,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.rim.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.vocab,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.vocab.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.navigator,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.navigator.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.properties,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.properties.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.validation,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.validation.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.dita,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.dita.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.fhir.xsd,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.fhir.xsd.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.basic,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.basic.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.test,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.test.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.tooling,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.tooling.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.common,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.common.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.core,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.core.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.edit,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.edit.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.fhir.feature,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.fhir.feature.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.transform,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.transform.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.ui,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.ui.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.source,3.0.0.201606070333
What could be the problem?
Current Time: Wed Apr 16 02:36:52 EDT 2025
Powered by FUDForum. Page generated in 0.07439 seconds
