Home » Modeling » TMF (Xtext) » Loading operator extension from Jar file
Loading operator extension from Jar file [message #1734022] Fri, 03 June 2016 02:43 Go to next message
Dear all.
I'm writing an library that is providing math primitives such as vectors, matrices, etc.
Currently, I have hard-coded the Xbase operators in the primitives by creating functions like:
public Vector operator_plus(Vector a) {
    Vector v = new Vector(this);
    v.add(a);
    return v;
The use of the operators in my DSL is working.
Now, I would like to move these functions into a static utility class similar to the MapExtensions provided by Xtext.
The problem is:
is it possible for the DSL compiler to automatically load this extension when the Jar file of my math library is present in the classpath of the compiled project?
I would like to find some automatic approach that do not requires to change neither the compiler's configuration nor its code.
I know how to add an extension in the DSL compiler. But I would like to know if the Xtext provides tools for dynamic loading.
All the best.
Stéphane.
Re: Loading operator extension from Jar file [message #1734149 is a reply to message #1734022] Sun, 05 June 2016 04:45 Go to previous messageGo to next message
hi i am not sure if i get your question, but extension classes like MapExtensions are registered through ImplicitlyImportedFeatures respectively StaticImplicitMethodsFeatureForTypeProvider
Re: Loading operator extension from Jar file [message #1734160 is a reply to message #1734149] Sun, 05 June 2016 10:34 Go to previous messageGo to next message
Thank you for your reply.
Are the ImplicityImportedFeatures or StaticImplicitMethodsFeatureForTypeProvider able to dynamically load the extensions by reading the MANIFEST file of a JAr file in the classpath.
In other words, is it possible to implicitly load features stored in a Jar file, just by adding this Jar file.
If not, I should specialize ImplicityImportedFeatures or StaticImplicitMethodsFeatureForTypeProvider in my DSL compiler.
All the best.
Stéphane.
Re: Loading operator extension from Jar file [message #1734164 is a reply to message #1734160] Sun, 05 June 2016 10:52 Go to previous message
I'd make the extension static and adapt implicitelyimortedfeatures. And yes the class file needed to be on the class path of the dsl file
Previous Topic:ISerializationContext cannot be resolved to a type
Next Topic:Referring an xcore enum in xtext
Current Time: Thu Nov 06 00:19:25 EST 2025
Powered by FUDForum. Page generated in 0.04327 seconds
