Change Process ID, BPMN2 elements ID [message #1729502] |
Thu, 14 April 2016 14:45  |
is it possible to change the process id or the BPMN2 elements id attribute in bpmn2-modeler mars 1.2.4?
(switched on Preferences / BPMN2 / Editor / Behavior / Show ID attribute for BPMN2 Elements)
Thanks in advance!
Re: Change Process ID, BPMN2 elements ID [message #1730398 is a reply to message #1729973] |
Mon, 25 April 2016 08:54   |
Thanks for your answer, Robert! Yes, we've done "the trick" with an XML editor, and changed the IDs consistently. Yes, its risky. But as I mentioned above, working with auto generated IDs "UserTask_1, ..." in our application configuration is sticky as well. The modeler could make it safer, eg. enable setting them by the user when creating new elements. We found other tools, and some of them has this feature, but lack in others, so the Eclipse BPMN Modeler is the best tool for us so far.
FUDForum. Page generated in 0.03363 seconds
