Home » Eclipse Projects » Oomph » Platform specific tasks(Is it feasible to configure tasks which are only executed on a specific target platform)
Platform specific tasks [message #1708261] Tue, 15 September 2015 01:58 Go to next message
VMarguments configuration is different on target platforms
(os=win32,ws=win32,arch=x86_64)
-Xmx2048m
(os=win32,ws=win32,arch=x86)
-Xmx768m
What would be the best way to configure such things?
Re: Platform specific tasks [message #1708264 is a reply to message #1708261] Tue, 15 September 2015 02:10 Go to previous messageGo to next message
Am 15.09.2015 um 07:58 schrieb Peter Kirschner:
> -Xmx2048m
> -Xmx768m
Sorry, you left out the context of your question. Maybe you explain what you'd do without Oomph to achieve what you want
to achieve...
Cheers
/Eike
http://www.esc-net.de
Re: Platform specific tasks [message #1708288 is a reply to message #1708264] Tue, 15 September 2015 04:01 Go to previous messageGo to next message
You are right.
I have a custom product which is installed on different architectures (x86 and x86_64).
How do I specify different vmargs for those different target architectures?
Is that feasible and if yes how?
Re: Platform specific tasks [message #1708296 is a reply to message #1708288] Tue, 15 September 2015 04:52 Go to previous messageGo to next message
Am 15.09.2015 um 10:01 schrieb Peter Kirschner:
> You are right.
Still trying to figure out what you're asking. Is this "custom product" a .product file (and your question is about the
target platform) or an Oomph product in a custom .setup file (and your question is about authoring that setup file)?
Cheers
/Eike
Re: Platform specific tasks [message #1708303 is a reply to message #1708296] Tue, 15 September 2015 06:37 Go to previous messageGo to next message
Hi Eike,
I suppose Peter is referring to the EclipseIni nodes one can specify in a setup model. I am facing exactly that problem: How can I specify an enhancement of the eclipse.ini in the setup model depending on the processor architecture? If the Oomph installer installs my product on a 32 bit architecture, I want to set the maxmimum heap size to 1.5G, if it is a 64 bit architecture, I want to set it to 4G. I would need to attach a condition to the EclipseIni elements in the setup model.
Stephan
Re: Platform specific tasks [message #1708306 is a reply to message #1708303] Tue, 15 September 2015 06:46 Go to previous message
Am 15.09.2015 um 12:37 schrieb Stephan Hildebrandt:
> Hi Eike,
Okay, I see now ;-)
Unfortunately we have no solution in place already. We've discussed a few possible approaches, though:
1) Add environment filter attributes (in whatever exact form) to SetupTask.
2) Add a new string filter (probably more an integer filter) that reduces an ideal (for 64 bit) value to the maximum
value on the current system.
3) Add special logic to EclipseIniTask that detects and fixes possible problems for any of the memory-related args.
Except for https://bugs.eclipse.org/bugs/show_bug.cgi?id=429245 (conditional task execution, which is the most complex
approach) we have no enhancement request, yet, for this topic. Please submit one, so that we can continue the discussion
there...
Cheers
/Eike
Previous Topic:Start Installer in Advanced Mode
Next Topic:New Installer Use
Current Time: Sat Oct 25 21:16:39 EDT 2025
Powered by FUDForum. Page generated in 0.05198 seconds
