Home » Eclipse Projects » Oomph » Let oomph import from multiple git - repositories
Let oomph import from multiple git - repositories [message #1706967] |
Tue, 01 September 2015 08:27 |
Maksim Melnik Messages: 52 Registered: August 2015 |
Member |
since i work on a big project, i want to be able to define multiple branches, from which
i want to import, during the eclipse installation time. Since i want to do it during the
installation time, i need induced choices. But here, my problem is, that if i define an
import task with induced choices in it, then the number of clone repos in the
installation menu is fixed. So I only have a fixed number of induced choices , whereas i
want to add multiple clone repos in the installation time. Is there a solution for this ?
Thank you for your help,
Maksim
[Updated on: Tue, 01 September 2015 10:04] Report message to a moderator
Re: Let oomph import from multiple git - branches [message #1706979 is a reply to message #1706967] |
Tue, 01 September 2015 09:27 |
Ed Merks Messages: 33264 Registered: July 2009 |
Maksim,
Comments below.
On 01/09/2015 10:27 AM, Maksim Melnik wrote:
> Hello,
I'm not sure what importing multiple branches means...
Given I don't understand what the first sentence means, I don't follow
how this leads to induced choices. Choices of what?
> import task
A project's import task?
Number of clone repos in installation menu. I'm not sure which mean
shows clone repos...
> So I only have a fixed number of induced choices , whereas i want to
> for this ?
Sorry, I completely don't follow what you're asking. If this is about
choices for the checking branch of a clone, which is
${scope.project.stream.name} in the template, you can always change that
to refer to a variable with choices that you author yourself...
Ed Merks
Re: Let oomph import from multiple git - branches [message #1706980 is a reply to message #1706979] |
Tue, 01 September 2015 10:03 |
Member |
Hey Ed,
sorry for my unclear question and thank you for your reply. I will try to put it another way.
I have multiple git repositories.
However i only want to clone and import into workspace only a subset of them. The subset may differ depending on what i want to work on.
In order to clone a git repository , as far as i understand, a git-clone task is required with either induced choices or a hard-coded RemoteURI.
Now my problem is, since i want to clone different ammount of repositories, i want to have a flexible number of induced choices, so that in the installation menu i can add multiple git clone paths.
Since i don't know how to make the number of induced choices flexible i've tried to find a workaround.
I tried defining multiple .setup files, each of which clones a single project into workspace, but then i get the problem, that every project is imported into all work-sets , instead of just into the work-set it belongs to.
I hope my problem is clear now.
Maksim
Re: Let oomph import from multiple git - branches [message #1706987 is a reply to message #1706980] |
Tue, 01 September 2015 10:46 |
Maksim,
Comments below.
On 01/09/2015 12:03 PM, Maksim Melnik wrote:
> Hey Ed,
> I have a multiple git repositories. However i only want to clone and
> RemoteURI.
The choice of repository URI is about which variant of to choose for a
given repository, i.e.., git, ssh, https and so on. It's not about
choice to clone or not...
I think this is just the wrong path.
> belongs to.
I imagine each different clone should maintain a setup for the projects
in that clone. You choose to work on those projects by virtue of
choosing that project setup.
I'm trying to figure out what you mean by "every project is imported
into all work-sets". Are there working set tasks involved in this?
It's clear a project can't be imported into the workspace unless there
is a git clone for it, so I'm unsure what problem you're having.
> Maksim
Ed Merks
Re: Let oomph import from multiple git - branches [message #1706993 is a reply to message #1706987] |
Tue, 01 September 2015 11:49 |
Member |
Ed,
Comments below.
> Hey Ed,
> RemoteURI.
Okay, but can i define multiple locations in this section?
> belongs to.
Yes there are work-set tasks. When i chose multiple .setup files in the installation menu, i get multiple working sets in my eclipse. That's fine. The problem is, that each working-set, imports all projects. So i get many repetitions in each set.
What i want is, that each work-set contains only projects , which are cloned by it's setup file.
> Maksim
Re: Let oomph import from multiple git - branches [message #1706996 is a reply to message #1706993] |
Tue, 01 September 2015 12:04 |
Maksim,
Comments below.
On 01/09/2015 1:49 PM, Maksim Melnik wrote:
> Ed,
> Comments below.
>> Hey Ed,
A clone only has one remote URI.
So that's just a matter of how you define their contents. A
repository predicate lets you specify "all projects in the same
repository as some specific project". There are many predicates
available; name predicates are commonly used as well.
>> Maksim
Ed Merks
Current Time: Mon Jan 13 15:35:55 GMT 2025
Powered by FUDForum. Page generated in 0.04738 seconds
