Getting a naming exception for a DataSource that I can find programatically [message #1706662] |
Fri, 28 August 2015 13:06 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Julie MacNaught![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=jmacna%40us.ibm.com) Messages: 1 Registered: August 2015 |
I am using EclipseLink 2.5.2 with Liberty 8.5.5.5. This worked in the past with Tomcat 7.
I have a method that returns a ThreadLocal EntityManager that detects whether it is being run from a web container or a standalone java application. It tries to find a JNDI DataSource, but falls back to using a properties file if it cannot be found.
The problem is that the code finds the DataSource just fine, but then EclipseLink claims that it cannot be found.
Here's the stack, and I'll show the code after the stack.
[WARNING ] DSRA0174W: Warning: GenericDataStoreHelper is being used.
2015-08-28T08:40:45,047(Default Executor-thread-2) INFO : EMHandlerImpl.em: Got DataSource from JNDI
[EL Info]: 2015-08-28 08:40:45.163--ServerSession(84898271)--EclipseLink, version: Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd
[EL Severe]: ejb: 2015-08-28 08:40:45.179--ServerSession(84898271)--Exception [EclipseLink-7060] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.ValidationException
Exception Description: Cannot acquire data source [java:/comp/env/jdbc/MANDA].
Internal Exception: javax.naming.NameNotFoundException: java:/comp/env/jdbc/MANDA
2015-08-28T08:40:45,180(Default Executor-thread-2) ERROR: EMHandlerImpl.em: Cannot create EntityManager
javax.persistence.PersistenceException: Exception [EclipseLink-7060] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.ValidationException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:766) ~[?:?]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getAbstractSession(EntityManagerFactoryDelegate.java:204) ~[?:?]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:304) ~[?:?]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:336) ~[?:?]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:302) ~[?:?]
at com.ibm.finance.portman.store.EMHandlerImpl.em(EMHandlerImpl.java:130) [?:1.4-SNAPSHOT]
at com.ibm.finance.portman.store.MandaDaoImpl.em(MandaDaoImpl.java:98) [?:1.4-SNAPSHOT]
at com.ibm.finance.portman.store.MandaDaoImpl.getUserByEmail(MandaDaoImpl.java:1000) [?:1.4-SNAPSHOT]
at com.ibm.finance.portman.service.common.MandaRequestBase.<init>(MandaRequestBase.java:144) [?:1.4-SNAPSHOT]
at com.ibm.finance.portman.service.GetUsersRequest.<init>(GetUsersRequest.java:10) [?:?]
at com.ibm.finance.portman.service.UserService.getUsers(UserService.java:79) [?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_45]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_45]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_45]
at java.lang.reflect.Method.invoke(Method.java:497) ~[?:1.8.0_45]
at org.apache.wink.server.internal.handlers.InvokeMethodHandler.handleRequest(InvokeMethodHandler.java:63) [?:1.4]
at org.apache.wink.server.handlers.AbstractHandler.handleRequest(AbstractHandler.java:33) [?:1.4]
at org.apache.wink.server.handlers.RequestHandlersChain.handle(RequestHandlersChain.java:26) [?:1.4]
at org.apache.wink.server.handlers.RequestHandlersChain.handle(RequestHandlersChain.java:22) [?:1.4]
at org.apache.wink.server.handlers.AbstractHandlersChain.doChain(AbstractHandlersChain.java:63) [?:1.4]
at org.apache.wink.server.internal.handlers.CreateInvocationParametersHandler.handleRequest(CreateInvocationParametersHandler.java:54) [?:1.4]
at org.apache.wink.server.internal.handlers.FindResourceMethodHandler.handleResourceMethod(FindResourceMethodHandler.java:151) [?:1.4]
at org.apache.wink.server.internal.handlers.FindResourceMethodHandler.handleRequest(FindResourceMethodHandler.java:65) [?:1.4]
at org.apache.wink.server.internal.handlers.FindRootResourceHandler.handleRequest(FindRootResourceHandler.java:95) [?:1.4]
at org.apache.wink.server.internal.handlers.HeadMethodHandler.handleRequest(HeadMethodHandler.java:53) [?:1.4]
at org.apache.wink.server.internal.handlers.OptionsMethodHandler.handleRequest(OptionsMethodHandler.java:46) [?:1.4]
at org.apache.wink.server.internal.handlers.SearchResultHandler.handleRequest(SearchResultHandler.java:33) [?:1.4]
at org.apache.wink.server.internal.log.ResourceInvocation.handleRequest(ResourceInvocation.java:92) [?:1.4]
at org.apache.wink.server.internal.log.Requests.handleRequest(Requests.java:76) [?:1.4]
at org.apache.wink.server.handlers.AbstractHandlersChain.run(AbstractHandlersChain.java:48) [?:1.4]
at org.apache.wink.server.internal.RequestProcessor.handleRequestWithoutFaultBarrier(RequestProcessor.java:207) [?:1.4]
at org.apache.wink.server.internal.RequestProcessor.handleRequest(RequestProcessor.java:154) [?:1.4]
at org.apache.wink.server.internal.servlet.RestServlet.service(RestServlet.java:119) [?:1.4]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668) [com.ibm.ws.javaee.servlet.3.0_1.0.8.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1285) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:776) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:473) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget(WebAppFilterChain.java:135) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:89) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at org.apache.logging.log4j.web.Log4jServletFilter.doFilter(Log4jServletFilter.java:71) [?:2.2]
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:206) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:86) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:978) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1100) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:4845) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.osgi.DynamicVirtualHost$2.handleRequest(DynamicVirtualHost.java:297) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:981) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.webcontainer.osgi.DynamicVirtualHost$2.run(DynamicVirtualHost.java:262) [com.ibm.ws.webcontainer_1.0.8.jar:?]
at com.ibm.ws.http.dispatcher.internal.channel.HttpDispatcherLink$TaskWrapper.run(HttpDispatcherLink.java:955) [com.ibm.ws.transport.http_1.0.8.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_45]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_45]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_45]
Caused by: org.eclipse.persistence.exceptions.ValidationException:
at org.eclipse.persistence.exceptions.ValidationException.cannotAcquireDataSource(ValidationException.java:520) ~[?:?]
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIConnector.java:109) ~[?:?]
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162) ~[?:?]
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.setOrDetectDatasource(DatabaseSessionImpl.java:204) ~[?:?]
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:741) ~[?:?]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:239) ~[?:?]
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:685) ~[?:?]
... 75 more
Caused by: javax.naming.NameNotFoundException: java:/comp/env/jdbc/MANDA
at com.ibm.ws.jndi.url.contexts.javacolon.internal.JavaURLName.<init>(JavaURLName.java:84) ~[?:?]
at com.ibm.ws.jndi.url.contexts.javacolon.internal.JavaURLNameParser.parse(JavaURLNameParser.java:40) ~[?:?]
at com.ibm.ws.jndi.url.contexts.javacolon.internal.JavaURLNameParser.parse(JavaURLNameParser.java:61) ~[?:?]
at com.ibm.ws.jndi.url.contexts.javacolon.internal.JavaURLContext$NameUtil.<init>(JavaURLContext.java:461) ~[?:?]
at com.ibm.ws.jndi.url.contexts.javacolon.internal.JavaURLContext.lookup(JavaURLContext.java:308) ~[?:?]
at org.apache.aries.jndi.DelegateContext.lookup(DelegateContext.java:157) ~[?:?]
at javax.naming.InitialContext.lookup(InitialContext.java:421) ~[?:1.8.0_45]
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIConnector.java:103) ~[?:?]
... 75 more
2015-08-28T08:40:45,194(Default Executor-thread-2) ERROR: EMHandlerImpl.em: failed to initialize entity manager
Here's the code:
public static EntityManager em()
if (emFactory == null) {
LOG.debug("initializing entity-manager factory");
Properties props = null;
Context initCtx;
try {
// try getting it using just the name, and it will use the jndi service
// this is when the data source is configured in the container
initCtx = new InitialContext();
Context envCtx = (Context) initCtx.lookup("java:comp/env");
DataSource ds = (DataSource) envCtx.lookup("jdbc/MANDA");
props = new Properties();
props.setProperty("javax.persistence.nonJtaDataSource", "java:/comp/env/jdbc/MANDA");
emFactory = (EntityManagerFactory) Persistence.createEntityManagerFactory(DB_NAME, props);
LOG.info("Got DataSource from JNDI");
} catch (Exception e) {
// we may not be running in a container, so use properties to find the database
try {
props = getJPAProperties();
LOG.info("Configured data source from JPAProperties");
} catch (Exception ex) {
LOG.error("Exception getting properties", ex);
LOG.error("No EntityManagerFactory created!");
} else {
LOG.debug("********EntityManagerFactory created");
EntityManager entityManager = tlEntityManager.get();
if (entityManager == null || ! entityManager.isOpen()) {
LOG.debug("******** Creating EntityManager");
try {
entityManager = emFactory.createEntityManager();
LOG.debug("********Entity manager created");
LOG.error("Cannot create EntityManager", ex);
if (entityManager != null)
if (LOG.isDebugEnabled()) {
LOG.debug("<< Open " + entityManager.hashCode());
tlEntityManager.set(entityManager);
else
LOG.error("failed to initialize entity manager");
tlEntityManager.set(null);
return entityManager;
This really has me stumped, so any suggestions are greatly appreciated.
FUDForum. Page generated in 0.02919 seconds
