Home » Language IDEs » Java Development Tools (JDT) » code formatter behaviour has changed from Luna to Mars(different code formatter behaviour when using Annotations on Enum types)
code formatter behaviour has changed from Luna to Mars [message #1704932] Mon, 10 August 2015 16:44 Go to next message
I'm getting different formatting outputs when defining Enum types with annotations between Luna and Mars. I work with my own code style formatter template, but even with Eclipse default templates (Eclipse built-in or Java Conventions) behaviour is different between Luna and Mars.
Sample code in Luna:
public enum TestFormatterEnum {
@Translate("Element Type One")
ElementTypeOne,
@Translate("Element Type Two")
ElementTypeTwo,
@Translate("Element Type Three")
ElementTypeThree;
Same code in Mars after formatting:
@Translate("Element Type One") ElementTypeOne,
@Translate("Element Type Two") ElementTypeTwo,
@Translate("Element Type Three") ElementTypeThree;
I'm not able to find an option to customize this with the template editor...
Any advice (different than using comment // at the end of line or disable formatter) appreciated.
Re: code formatter behaviour has changed from Luna to Mars [message #1705341 is a reply to message #1704932] Thu, 13 August 2015 18:04 Go to previous message
The setting you need is New Lines -> Annotations -> Insert new line after type annotations.
In Luna the formatter probably didn't remove the line breaks because of the "Never join already wrapped lines" setting. Now this behavior changed - see https://bugs.eclipse.org/bugs/show_bug.cgi?id=372801 for more details.
Previous Topic:Behavior change when formatting else-if blocks
Next Topic:Cannot use Lambda expressions
Current Time: Sun Nov 30 08:07:22 EST 2025
Powered by FUDForum. Page generated in 0.03973 seconds
