Re: Create launcher shortcut [message #1703823 is a reply to message #1703748] |
Wed, 05 August 2015 08:42 |
Ed Merks Messages: 33264 Registered: July 2009 |
Claudio,
Comments below.
On 05/08/2015 4:25 AM, Claudio Weiler wrote:
> Thanks Ed,
> Only using in advanced mode... If it had been a snake, it would have
> bitten me (by now).
> But, 2 other questions...
> Can I make this in advanced mode?
We've not provided the options for that in advanced mode, but we've
talked about it. You could open an enhancement request and perhaps
even contribute a Gerrit patch; the logic for creating the shortcuts is
in
org.eclipse.oomph.setup.internal.installer.KeepInstallerUtil.createShortCut(String,
String, String, String).
> In simple mode the installer ignores my settings for installation
> folder! Is there a way to set default installation folder (base) for
> simple mode?
Unfortunately it's using a totally different "Variables" page
implementation that does not reuse all the rules/logic that's are in
place for the "Variables" page implementation of the advanced
installer. I suppose that too could be enhanced...
Ed Merks
Re: Create launcher shortcut [message #1703949 is a reply to message #1703898] |
Thu, 06 August 2015 04:55 |
Claudio,
Comments below.
On 05/08/2015 6:57 PM, Claudio Weiler wrote:
> Ed Merks wrote on Wed, 05 August 2015 05:42
>> ... Unfortunately it's using a totally different "Variables" page
>> implementation that does not reuse all the rules/logic ...
> Why this Ed? Sorry if I am annoying, I don't know if you are part of
> Oomph team...
I wrote the VariablePage, not the SimpleVariablePage.
> Concepts of simple and advanced should be just for the end user,
> ability to perform some adjustments like network proxies and ssh keys...
Of course different user interfaces require different code. The simple
page doesn't give a choice of installation layout rules. It uses
org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.getDefaultInstallationFolder()
to determine the folder name. On the advanced page, it uses the logic
in
org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.filter(String,
String) to determine the folder name.
> But, besides that, there is other settings ignored/bypassed by simple
> mode? I need to make several customization on 3 different products
> (Oomph setups).
That's the only one that jumps to mind.
> Thanks!!
Ed Merks
FUDForum. Page generated in 0.03597 seconds
