Home » Eclipse Projects » Virgo » Virgo Tools for Eclipse Luna and Mars
Virgo Tools for Eclipse Luna and Mars [message #1699590] Thu, 25 June 2015 09:36 Go to next message
Vincenzo Caselli is currently offline Vincenzo CaselliFriend
Hi all,
I tried to install the Virgo Tools both in Eclipse Luna and in Mars (JEE packages), from this update site:
"Virgo IDE Releases" - http://download.eclipse.org/virgo/release/tooling
- Eclipse Virgo Tools 1.0.1.201302270038-RELEASE
but I got errors (see below).
Instead all il working well with Kepler.
Some suggestions?
Thank you very much.
Vincenzo
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse Virgo Tools 1.0.1.201302270038-RELEASE (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201302270038-RELEASE)
Software currently installed: Eclipse IDE for Java EE Developers 4.5.0.20150621-1200 (epp.package.jee 4.5.0.20150621-1200)
Only one of the following can be installed at once:
OSGi System Bundle 3.8.1.v20120830-144521 (org.eclipse.osgi 3.8.1.v20120830-144521)
OSGi System Bundle 3.10.100.v20150529-1857 (org.eclipse.osgi 3.10.100.v20150529-1857)
Cannot satisfy dependency:
From: Eclipse IDE for Java EE Developers 4.5.0.20150621-1200 (epp.package.jee 4.5.0.20150621-1200)
To: org.eclipse.epp.package.jee.feature.feature.group
From: EPP Java EE IDE Feature 4.5.0.20150621-1200 (org.eclipse.epp.package.jee.feature.feature.group 4.5.0.20150621-1200)
To: org.eclipse.m2e.feature.feature.group 0.0.0
From: Maven Integration for Eclipse 1.6.0.20150526-2032 (org.eclipse.m2e.core 1.6.0.20150526-2032)
To: bundle org.eclipse.osgi 3.10.0
From: m2e - Maven Integration for Eclipse (includes Incubating components) 1.6.0.20150526-2032 (org.eclipse.m2e.feature.feature.group 1.6.0.20150526-2032)
To: org.eclipse.m2e.core
From: Eclipse Virgo Tools 1.0.1.201302270038-RELEASE (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201302270038-RELEASE)
To: org.eclipse.virgo.ide.manifest.core [1.0.1.201302270038-RELEASE]
From: Eclipse Virgo IDE (Manifest Core) 1.0.1.201302270038-RELEASE (org.eclipse.virgo.ide.manifest.core 1.0.1.201302270038-RELEASE)
To: bundle org.eclipse.virgo.kernel.artifact 0.0.0
From: Virgo Kernel Artifact Integration 3.6.0.RELEASE (org.eclipse.virgo.kernel.artifact 3.6.0.RELEASE)
To: package org.eclipse.virgo.nano.serviceability [3.6.0,3.7.0)
From: Virgo Nano Core 3.6.0.RELEASE (org.eclipse.virgo.nano.core 3.6.0.RELEASE)
To: package org.eclipse.osgi.internal.baseadaptor 0.0.0
[Updated on: Thu, 25 June 2015 09:36]
Report message to a moderator
Re: Virgo Tools for Eclipse Luna and Mars [message #1699598 is a reply to message #1699590] Thu, 25 June 2015 10:00 Go to previous messageGo to next message
GianMaria Romanato is currently offline GianMaria RomanatoFriend
Member
Hi Vincenzo,
the Virgo tools are not yet ready for Mars, but this will change very soon as the team is working hard to close a Mars compatible release.
If you cannot wait for the official release, you may try installing a snapshot from http://download.eclipse.org/virgo/snapshot/tooling
Note that the last time I installed a snapshot in Mars, I had to use Java8 for running Eclipse, otherwise the Virgo tools would not work.
GianMaria.
Developing for Virgo using PDE: http://bit.ly/1w0tTit
Global JNDI in Virgo: http://bit.ly/1to42mn
Hyperic to monitor Virgo: http://bit.ly/W1Fst9
Profile Virgo with JProfiler http://bit.ly/1FBLGCw
Re: Virgo Tools for Eclipse Luna and Mars [message #1699600 is a reply to message #1699590] Thu, 25 June 2015 10:12 Go to previous messageGo to next message
Florian Waibel is currently offline Florian WaibelFriend
Hi Vincenzo,
we just fixed Bug 438506 (Eclipse 4.4 is not supported The installation cannot be completed as requested.) but have not created a new milestone/release for Virgo Tooling yet.
Please use the snapshot update site: http://download.eclipse.org/virgo/snapshot/tooling.
florian
Re: Virgo Tools for Eclipse Luna and Mars [message #1699621 is a reply to message #1699600] Thu, 25 June 2015 11:29 Go to previous messageGo to next message
Hi GianMaria, Florian,
thank you!
Just for a note I tried that update site on Mars (with Java8) and had this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Eclipse Virgo Tools 1.0.1.201506250039-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201506250039-SNAPSHOT)
Missing requirement: Artifact Repository 3.7.0.D-20150624084347 (org.eclipse.virgo.repository 3.7.0.D-20150624084347) requires 'package org.eclipse.virgo.util.osgi.manifest [3.7.0,4.0.0)' but it could not be found
From: Eclipse Virgo Tools 1.0.1.201506250039-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201506250039-SNAPSHOT)
To: org.eclipse.virgo.repository [3.7.0.D-20150624084347]
I will try it next with Luna (4.4)
Thank you
Vincenzo
[Updated on: Thu, 25 June 2015 11:30]
Re: Virgo Tools for Eclipse Luna and Mars [message #1699721 is a reply to message #1699621] Fri, 26 June 2015 07:39 Go to previous messageGo to next message
Sorry, I have to correct myself: today I retried with a brand new Mars/JEE+Java8 and a brand new workspace:
the error is related to missing org.json bundle.
  Software being installed: Eclipse Virgo Tools 1.0.1.201506260038-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201506260038-SNAPSHOT)
  Missing requirement: Eclipse Virgo IDE (Server Core) 1.0.1.201506260038-SNAPSHOT (org.eclipse.virgo.ide.runtime.core 1.0.1.201506260038-SNAPSHOT) requires 'bundle org.json 0.0.0' but it could not be found
    From: Eclipse Virgo Tools 1.0.1.201506260038-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201506260038-SNAPSHOT)
    To: org.eclipse.virgo.ide.runtime.core [1.0.1.201506260038-SNAPSHOT]
seems like Mars/JEE doesn't contain org.json ... which is quite strange ...
With Mars/JEE+Java7 instead the detailed error is:
  Missing requirement: OSGi Framework Editor UI (Incubation) 0.2.0.201206060754 (org.eclipse.libra.framework.editor.ui 0.2.0.201206060754) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
  Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.0.201212132137 (org.eclipse.libra.framework.editor.ui 0.3.0.201212132137) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
  Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.0.201305070844 (org.eclipse.libra.framework.editor.ui 0.3.0.201305070844) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
  Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.0.201305151323 (org.eclipse.libra.framework.editor.ui 0.3.0.201305151323) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
  Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.0.201305311343 (org.eclipse.libra.framework.editor.ui 0.3.0.201305311343) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
  Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.1.201405141436 (org.eclipse.libra.framework.editor.ui 0.3.1.201405141436) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
    To: org.eclipse.virgo.ide.runtime.ui [1.0.1.201506260038-SNAPSHOT]
    From: Eclipse Virgo IDE (Server UI) 1.0.1.201506260038-SNAPSHOT (org.eclipse.virgo.ide.runtime.ui 1.0.1.201506260038-SNAPSHOT)
    To: bundle org.eclipse.libra.framework.editor.ui 0.0.0
With Luna/JEE SR2 instead all is working well, both with Java7 and Java8
Vincenzo
Re: Virgo Tools for Eclipse Luna and Mars [message #1699787 is a reply to message #1699721] Fri, 26 June 2015 15:07 Go to previous messageGo to next message
Hi Vincenzo,
I successfully installed the snapshot you tried on OSX and Windows with Java 7.
(the build produces Java 7 compatible byte-code since a few days now)
@see: https://bugs.eclipse.org/bugs/attachment.cgi?id=254754
Java 8 on OSX works for me, too.
If I remember correctly I had such problems when I accidentally unchecked "Contact all update sites during install to find required software" during installation.
florian
[Updated on: Fri, 26 June 2015 15:13]
Re: Virgo Tools for Eclipse Luna and Mars [message #1699833 is a reply to message #1699787] Fri, 26 June 2015 23:47 Go to previous messageGo to next message
Hi Florian,
thank you for your answer.
I have always the option "Contact all update sites ..." checked, but ...
... it turned out that I hit this issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=470900
(==oomph cache blocks access to some update sites)
so the needed features where not allowed to be correctly retrieved.
(indeed I noticed that in last few days when I hit by chance Mars main update site I received an error, but didn't take much care about this...)
In the end just by deleting oomph cache
C:\Users\<user>\.eclipse\org.eclipse.oomph.p2\cache
solved the problem and now I can install Virgo Tools snapshot on Mars, both with Java7 and with Java8.
Thank you very much!
Vincenzo
Re: Virgo Tools for Eclipse Luna and Mars [message #1699917 is a reply to message #1699833] Mon, 29 June 2015 09:30 Go to previous messageGo to next message
Hi Vincenzo,
thanks for trying hard to solve this issue and keeping us in the loop.
I always used clean installations to avoid side-effects during my tests, which explains why I didn't hit this problem.
florian
Re: Virgo Tools for Eclipse Luna and Mars [message #1699945 is a reply to message #1699917] Mon, 29 June 2015 12:42 Go to previous messageGo to next message
Hi Florian,
me too was thinking to be using a clean installation (I always unzipped the eclipse package in a brand new folder and used a brand new workspace),
but keep in mind that since Mars onwards everyone is always using Oomph (often wihtout being aware of that!) and so the folder <user>\.eclipse\org.eclipse.oomph.p2\cache enters in the play inevitably ... Smile
Vincenzo
Re: Virgo Tools for Eclipse Luna and Mars [message #1721792 is a reply to message #1699590] Sat, 30 January 2016 19:14 Go to previous messageGo to next message
Gita Singh is currently offline Gita SinghFriend
I'm trying to install Virgo Tools on Eclipse Mars and Luna JEE packages from the site http://download.eclipse.org/virgo/snapshot/tooling
I don't seem to find the Eclipse Virgo Tools listed on Mac OS X Yosemite. I had successfully installed it on Windows. I see from the posts below that it can be installed on Mac with Mars JEE/Java8. Could you tell me why I'm not seeing the Virgo Tools listed? (the only ones listed are :
Enterprise Tools for the OSGi Service Platform 1.0.0.07M-cLWO767UEMUMUMcUMd6
Enterprise Tools for the OSGi Service Platform SDK 1.0.0.07M-cLWOH57UEMUMUMcUMd6
Virgo From Eclipse RT.
Thanks in advance for your help!
Re: Virgo Tools for Eclipse Luna and Mars [message #1722039 is a reply to message #1721792] Tue, 02 February 2016 12:06 Go to previous message
The snapshot tooling is linked to our Hudson instance and our Hudson was down: https://bugs.eclipse.org/bugs/show_bug.cgi?id=486982
Since the webmasters restarted our Hudson could you please retry?
florian
Previous Topic:Virgo tooling and servlet 3.0
Next Topic:VIRGO Server consumes 100% CPU Usage
Current Time: Thu Dec 26 11:29:41 GMT 2024
Powered by FUDForum. Page generated in 0.04222 seconds
