Home » Eclipse Projects » Oomph » Installer fails to download Mars final release?
Installer fails to download Mars final release? [message #1699569] |
Thu, 25 June 2015 08:10 |
Jörg von Frantzius Messages: 21 Registered: July 2009 |
the Eclipse installer managed to update itself (successfully, as I saw the executable was renamed ...)
However, it fails to download from the Mars update site:
Executing bootstrap tasks
Product org.eclipse.products.epp.package.jee.mars
Bundle org.eclipse.oomph.setup 1.1.0.v20150610-1559, build=1448, branch=3b890d6e2fe59fb84fc5fb689b8621eabc2464ca, commit=3b890d6e2fe59fb84fc5fb689b8621eabc2464ca
Bundle org.eclipse.oomph.setup.core 1.1.0.v20150619-0556, build=1478, branch=f9c6c715c05a4d780d0aea1f878f0ed756e9fa41, commit=f9c6c715c05a4d780d0aea1f878f0ed756e9fa41
Bundle org.eclipse.oomph.setup.installer 1.1.0.v20150619-1128, build=1478, branch=f9c6c715c05a4d780d0aea1f878f0ed756e9fa41, commit=f9c6c715c05a4d780d0aea1f878f0ed756e9fa41
Bundle org.eclipse.oomph.setup.p2 1.1.0.v20150609-0914, build=1448, branch=3b890d6e2fe59fb84fc5fb689b8621eabc2464ca, commit=3b890d6e2fe59fb84fc5fb689b8621eabc2464ca
Performing P2 Director (Eclipse IDE for Java EE Developers (Mars))
Offline = false
Mirrors = true
Resolving 6 requirements from 3 repositories to /home/jfrantzius/apps/eclipse-ee-mars/eclipse
Requirement epp.package.jee [4.5.0,4.6.0)
Requirement org.eclipse.platform.feature.group [4.5.0,4.6.0)
Requirement org.eclipse.rcp.feature.group [4.5.0,4.6.0)
Requirement org.eclipse.jdt.feature.group [3.11.0,3.12.0)
Requirement org.eclipse.pde.feature.group [3.11.0,3.12.0)
Requirement org.eclipse.oomph.setup.feature.group
Repository http://download.eclipse.org/technology/epp/packages/mars
Repository http://download.eclipse.org/releases/mars/201506241002
Repository http://download.eclipse.org/oomph/updates/latest
Adding repository http://download.eclipse.org/oomph/updates/latest
Adding repository http://download.eclipse.org/technology/epp/packages/mars
Adding repository http://download.eclipse.org/releases/mars/201506241002
ERROR: org.eclipse.equinox.p2.metadata.repository code=1000 No repository found at http://download.eclipse.org/technology/epp/packages/mars.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:395)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:116)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.fail(CachingRepositoryManager.java:300)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:196)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:394)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1338)
at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:416)
Took 189 seconds.
There are failed tasks.
Press Back to choose different settings or Cancel to abort.
I can open http://download.eclipse.org/technology/epp/packages/mars in my browser and get to see the page that says that this is an Eclipse update site.
Does anybody experience the same problem?
Jörg
Re: Installer fails to download Mars final release? [message #1699577 is a reply to message #1699569] |
Thu, 25 June 2015 08:28 |
Ed Merks Messages: 33264 Registered: July 2009 |
Yes, that was reported in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=470900 but if you try
again now (rerun the installer you've already downloaded), that problem
should be fixed (or avoided, rather, with no need for any updates).
On 25/06/2015 10:10 AM, Jörg von Frantzius wrote:
> Offline = false
> Mirrors = true
> Adding repository
> repository found at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Took 189 seconds.
> update site.
> Cheers,
> Jörg
Ed Merks
Re: Installer fails to download Mars final release? [message #1699586 is a reply to message #1699584] |
Thu, 25 June 2015 09:12 |
Jörg,
Are you on Linux perhaps with GTK3? I've seen this problem on my Ubuntu
15.04 virtual box. I noticed similar problems in the IDE itself, e.g.,
the Preferences... dialog is blank until it's resized. I think it's an
SWT GTK3 problem. I noticed that resizing the simple installer page
causes it to paint, and then the catalog items really are there, they've
just not been painted initially, and that's only a problem with GTK3.
Is that the case for you?
On 25/06/2015 10:57 AM, Jörg von Frantzius wrote:
> OK download now works in advanced mode, thanks!
> In simple mode, the list of products remains completely empty, though ...
Ed Merks
Current Time: Thu Dec 26 11:31:15 GMT 2024
Powered by FUDForum. Page generated in 0.03498 seconds
