Re: ACCELEO EDITOR is not working correctly [message #1698385 is a reply to message #1696282] |
Mon, 15 June 2015 08:43 |
I don't know why the Acceleo editor would behave in a different manner in your use case but I am not sure of the architecture of your configuration (But after switching to a eclipse plugin project, the ACCELEO editor is not working any more). Could you attach a sample project and a metamodel showing the issue to this discussion?
As for your questions:
1- The whole Acceleo project uses the standard Eclipse logging mechanism, you could open the error log view to see if Acceleo has any error to report
2- The class path of your project could be missing some dependencies to your metamodels, it's difficult to say
Stephane Bégaudeau, Obeo
Re: ACCELEO EDITOR is not working correctly [message #1698695 is a reply to message #1698385] |
Wed, 17 June 2015 10:23 |
Notice that .emtl (the compiled version of the .mtl) is no copied when
exporting the plugin project (I guess it's a bug) and you have to put it
into the plugin jar file manually, so maybe since you switched to a
plugin, that might be your problem.
Best,
Víctor
El 15/06/2015 a las 10:43, Stephane Begaudeau escribió:
> error to report
> Regards,
FUDForum. Page generated in 0.04145 seconds
