| synchronize [message #169652] |
Tue, 05 September 2006 15:03  |
Originally posted by: chadmichaeldavis.gmail.com
Hello.
I've very familiar with CVS from the command line. However, I don't
know of a synchronize command. What exactly does Eclipse's synchronize
command do? Is is some special update that doesn't pull down anything
except list of files that would be updated?
| Re: synchronize [message #170527 is a reply to message #169828] |
Tue, 12 September 2006 10:39  |
Originally posted by: eclipse4.rizzoweb.com
chad wrote:
> Eric Rizzo wrote:
>> chad wrote:
>>> Hello.
>>> synchronize command do? Is is some special update that doesn't pull
>>> down anything except list of files that would be updated?
>>> Thanks
>> Essentially, yes. But it is not a single CVS command, but rather a
>> combination of CVS commands and examination of the local workspace to
>> assemble a "preview" of incoming and outgoing changes. IMO, the most
>> powerful CVS tool I've ever used.
>> Hope this helps,
>> Eric
> Eric,
> I agree its powerful. Its just that I'm a little timid about invoking
> some what unknown actions on my source control.
The beauty of Synchronize is that it only queries your repository; no
changes are made unless you explicitly invoke them from the Synchronize
view (e.g., right-click an out-going change and choose Commit).
Even if you didn't believe that, you could create a label or branch and
test it out without fear; or create a dummy project/module in your
repository to play around with. But as I said, that would be totally
unnecessary since Eclipse won't do anything to your repository unless
you tell it to.
> Does Eclipse have a function equivalent to running cvs diff on two
> different versions of the same file? I know you can compare the file in
> your project to other versions, but sometimes I like to review histories
> and I use the cvs diff command with two specific versions of the file
> specified.
Sure. Select the file you're interested in, right-click and choose
Team > Show History. That will open the History view, where you can
select any two versions and compare them with each other via
right-click.
Hope this helps,
Eric
FUDForum. Page generated in 0.10877 seconds
