[SOLVED] Oomph was not installed in a proper way from a setup [message #1695724] |
Mon, 18 May 2015 16:02 |
Daniel Brenner Messages: 8 Registered: March 2012 |
I created my own setup file for my project setup. My goal was to get a environment setup. So there was no problem to create this setup. Works very well. So thanks for your great work.
My problem is, that I, as far a I understand the concept of Oomph in the right way, I do not come to the second Oomph phase. The first phase works well. All things defined in the setup file were executed. But the second phase never started. I investigated some time to find the problem. My conclusion is, that the Oomph bundles were not installed in the target IDE in a proper way. When I install Oomph with the build in update mechanism it works. There are no Oompf icons in the toolbar if I use setup files.
I need help. I used Oomph in the paste and it works as expected but now I'm a little bit frustrated.
What have I tested:
* I installed without the bundle pool
* I deleted the bundle pool
* I used different update sites and feature requirement settings
* I tested with build in setup files and examples
=> setup do not achieve the second phase.
thanks.
Daniel
[Updated on: Wed, 20 May 2015 09:06] Report message to a moderator
Re: Oomph was not installed in a proper way from a setup [message #1695762 is a reply to message #1695724] |
Tue, 19 May 2015 05:41 |
Hi Daniel,
I assume you that, by first and second phase, you mean the standalone installer and the IDE startup trigger. I suspect
that you haven't used Oomph in a while and meanwhile we've made Oomph less interruptive, which means that the startup
execution of setup tasks happens in the background (there should be an extra icon in the status bar next to the progress
indicator) and the main toolbar contributions are optional (you can enable them via Preferences | Oomph | Setup). To see
what happened you should be able to use the "Open Setup Log" action in the Navigate menu.
If there's really a problem, can you please paste the content of the setup.log file in
eclipse/configuration/org.eclipse.oomph.setup/ ?
Cheers
/Eike
http://www.esc-net.de
Am 18.05.2015 um 18:02 schrieb Daniel Brenner:
> What have I tested:
> thanks.
> Daniel
Cheers
/Eike
FUDForum. Page generated in 0.04549 seconds
