Home » Eclipse Projects » e(fx)clipse » how to add double window trim (toolbar) in efxclipse e4
how to add double window trim (toolbar) in efxclipse e4 [message #1690767] Tue, 31 March 2015 07:11 Go to next message
Bart Cichy is currently offline Bart CichyFriend
Is possible to set double toolbar in efxclipse e4 (both with side: top; one below second)?
<trimBars>
      <children xsi:type="menu:ToolBar"/>
</trimBars>
<trimBars>
</trimBars>
Re: how to add double window trim (toolbar) in efxclipse e4 [message #1690841 is a reply to message #1690767] Tue, 31 March 2015 14:42 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
No we'll only show the last one. Technically there's no reason why we
should not be able to render more than one so feel free to file a bug.
Tom
> one below second)?
> <trimBars>
> </trimBars>
> <trimBars>
> </trimBars>
> Regards
Re: how to add double window trim (toolbar) in efxclipse e4 [message #1690987 is a reply to message #1690841] Wed, 01 April 2015 12:41 Go to previous messageGo to next message
Thx
Re: how to add double window trim (toolbar) in efxclipse e4 [message #1690995 is a reply to message #1690987] Wed, 01 April 2015 13:13 Go to previous messageGo to next message
If you filed the bugzilla report please post the number so that others
here can add themselves to the report as well.
Tom
On 01.04.15 14:41, Bart Cichy wrote:
> Thx
> Regards
Re: how to add double window trim (toolbar) in efxclipse e4 [message #1691003 is a reply to message #1690995] Wed, 01 April 2015 14:17 Go to previous messageGo to next message
bugzilla id: 463675
Currently set as "wont fix". Is this will be reopen?
Re: how to add double window trim (toolbar) in efxclipse e4 [message #1691006 is a reply to message #1691003] Wed, 01 April 2015 14:21 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
If you want it to be supported in e(fx)clipse, you should open the bug for e(fx)clipse .. you assigned the bug to e4 in general.
Re: how to add double window trim (toolbar) in efxclipse e4 [message #1691009 is a reply to message #1691006] Wed, 01 April 2015 14:34 Go to previous messageGo to next message
Ok, thx for advice
bug id: 463692
Re: how to add double window trim (toolbar) in efxclipse e4 [message #1692700 is a reply to message #1691009] Fri, 17 April 2015 11:53 Go to previous messageGo to next message
Is this will be implemented in version 2.0.0 (or some nightly version)?
Re: how to add double window trim (toolbar) in efxclipse e4 [message #1692765 is a reply to message #1692700] Fri, 17 April 2015 18:06 Go to previous message
I can't promise - if you provide a patch I'll review and merge it. If
you really want this feature think about sponsored development -
http://efxclipse.bestsolution.at/services.html
Tom
Previous Topic:E(fx)clipse Or Standard OSGI With JavaFX
Next Topic:at.bestsolution.efxclipse.runtime.emf.databinding.edit on maven repo?
Current Time: Wed Feb 05 19:12:31 GMT 2025
Powered by FUDForum. Page generated in 0.04498 seconds
