Home » Eclipse Projects » e(fx)clipse » e(fx)clipse in based product
e(fx)clipse in based product [message #1692049] Mon, 13 April 2015 01:34 Go to next message
Luis De Bello is currently offline Luis De BelloFriend
Member
Hi guys,
I am trying to use e(fx)clips in a based product configuration using my own target platform and I am having some issues trying to include some bundle
I included "http://download.eclipse.org/efxclipse/runtime-shared-released/1.2.0/site/" in order to have
org.eclipse.fx.javafx
org.eclipse.fx.osgi
But after setting my target platform the bundle "org.eclipse.fx.osgi" is not available only the "org.eclipse.fx.osgi.sources" is there.
As far my understanding goes if I included the repository in my target platform I will not need to include the jfxrt.jar for java 7 , is this right? because I wanted to avoid issues in order to do my product running on java 7 and 8.
Thanks in advance.
Luis
Re: e(fx)clipse in based product [message #1692059 is a reply to message #1692049] Mon, 13 April 2015 06:13 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
So what feature did you select? fx.osgi is there! Did you looked into
the Content-Tab when you setup the target? And finally
org.eclipse.fx.osgi is a fragment to system.bundle! You can not set that
as a dependency on bundles.
Packaging JavaFX with your application is NEVER an option see
http://tomsondev.bestsolution.at/2012/08/01/javafx-2-2-and-osgi/
Tom
On 13.04.15 03:34, Luis De Bello wrote:
> Hi guys,
> bundle
> I included
> in order to have
> org.eclipse.fx.osgi
> Thanks in advance.
> Regards,
> Luis
Re: e(fx)clipse in based product [message #1692088 is a reply to message #1692059] Mon, 13 April 2015 11:05 Go to previous messageGo to next message
Member
Hi Thomas,
Thanks for your answer , I think that I should be missing some step because I cannot compile my code.
1- I used my own target platform some I added the following location
<location includeAllPlatforms="false" includeConfigurePhase="false" includeMode="slicer" includeSource="true" type="InstallableUnit">
<unit id="org.eclipse.fx.runtime.min.feature.feature.group" version="1.2.0.201501301028"/>
<repository location="http://download.eclipse.org/efxclipse/runtime-shared-released/1.2.0/site/"/>
</location>
it means that I choose "e(fx)eclipse - Minimal JavaFX OSGi integration bundles"
2 - Then I went to my plugin project and I added "org.eclipse.fx.javafx" as dependency
3- I checked the bundle "org.eclipse.fx.osgi" from the Target Platform State View in eclipse
4- I include the following in my eclipse.ini "reference\:file\:org.eclipse.fx.osgi_1.2.0.201501301028.jar" for the entry "osgi.framework.extensions" and restarted my eclipse
After doing these steps I am not able to compile my code which is looking for the FXCanvas.
Do you know which could be my mistake or issue?
Thanks in advance.
P.S: I think that the adaptor is the component which is doing the magic of locating the runtime for javafx so is really important to define it for my OSGi environment, do you know if I can use this in my deploy with tycho?
Re: e(fx)clipse in based product [message #1692090 is a reply to message #1692088] Mon, 13 April 2015 11:26 Go to previous messageGo to next message
On 13.04.15 13:06, Luis De Bello wrote:
> Hi Thomas,
Can not compile in the IDE or through maven?
> <repository
> </location>
> bundles"
That's ok
> as dependency
That's ok
That's ok
If you build your project with tycho or better assemble the final
product with p2 it will create the entry for you. If you control your
own eclipse.ini I think this setting is ok.
Once where does it not compile:
* IDE
* maven
If the problem is compilation with maven then this is expected because
jfxswt.jar is not on the classpath and you need to reconfigure tycho to
do so. See
http://git.eclipse.org/c/efxclipse/org.eclipse.efxclipse.git/tree/releng/org.eclipse.fx.ide.releng/pom.xml
Tom
> Thanks in advance.
> tycho?
Re: e(fx)clipse in based product [message #1692092 is a reply to message #1692090] Mon, 13 April 2015 11:46 Go to previous messageGo to next message
Member
Hi Tom
Thanks for your prompt response.
I cannot compile my code from the IDE, it cannot find the FXCanvas. I tried to restart the eclipse, set my target platform again, clean and build all project and it didn't work Sad
Regarding tycho you said that I need to include jfxswt.jar so does it mean that I will need java 8 to compile my code? Can't I build my product with tycho and java 7 using the jfxrt.jar?.
P.S: I included the adaptor in the eclipse.ini that I am using for develop
Thanks again for your feedback and help
Luis
Re: e(fx)clipse in based product [message #1692119 is a reply to message #1692092] Mon, 13 April 2015 15:24 Go to previous messageGo to next message
a) Compilation in the IDE:
So you tell me it is finding jfxrt.jar but you still have compile errors?
Can you show a screenshot of the "Plug-in Dependencies"-Classpath-Entry
in your Package Explorer?
b) Compilation with tycho
compile with java7: You need to add jfxrt.jar to the default compilation
classpath
compile with java8: You need to put jfxswt.jar to the default
compilation classpath
c) The Adapter has nothing to do with tooling!
That you added this to the eclipse.ini tells me that you have NOT
installed the e(fx)clipse tooling into your IDE hence the compilation
problems!
Please install
http://download.eclipse.org/efxclipse/updates-released/1.2.0/site to
your host IDE (not sure what happens we the custom entry you added happens)
Tom
On 13.04.15 13:46, Luis De Bello wrote:
> Hi Tom
> build all project and it didn't work :(
> Regards,
> Luis
Re: e(fx)clipse in based product [message #1692134 is a reply to message #1692119] Mon, 13 April 2015 19:09 Go to previous messageGo to next message
Member
Hi Tom,
I didn't add the jfxrt.jar to my classpath I thought it will be included by the bundle. Now I have added the jar to my classpath without adding to my runtime because it will selected by the adapter.
Do I need to include the jar to compile my project?
Image 1
https://www.dropbox.com/s/g2zxhuua0cd2xlt/Plug-in%20Dependencies%201.png?dl=0
Image 2
https://www.dropbox.com/s/joakwek893rk0gp/Plug-in%20Dependencies%202.png?dl=0
Thanks for the answer I will add the dependency
I will add the "osgi.framework.extensions" to my product file in order to use tycho.
Luis
[Updated on: Mon, 13 April 2015 19:16]
Report message to a moderator
Re: e(fx)clipse in based product [message #1692135 is a reply to message #1692134] Mon, 13 April 2015 19:30 Go to previous messageGo to next message
On 13.04.15 21:09, Luis De Bello wrote:
> Hi Tom,
I repeat you should NOT add the bundle to the classpath yourself - if
you would have installed the e(fx)clipse tooling it does that for you.
The adapters and bundles are pure runtime things and having to do with
the IDE compilation path created by PDE. So please install e(fx)clipse
tooling into your IDE.
Please stop doing that.
NO. Just install the e(fx)clipse tooling.
> to use tycho.
I can't follow. You don't have to add anything at all. p2 will take care
of everything when exporting with it.
I still have the feeling that you don't fully grasped how this works and
you still have NOT installed our Eclipse IDE tooling extension giving
you a specialized css-editor, ... .
Tom
Re: e(fx)clipse in based product [message #1692155 is a reply to message #1692135] Tue, 14 April 2015 02:41 Go to previous message
Member
Hi Thomas,
You were right after installing the Eclipse IDE tooling it start working Smile
Thanks for your help
Luis
Previous Topic:Eclipse Mars (with Java FX)
Next Topic:E(fx)clipse Or Standard OSGI With JavaFX
Current Time: Wed Feb 05 17:59:00 GMT 2025
Powered by FUDForum. Page generated in 0.04179 seconds
