| TextObjectEditor - setMultiLine(true) not working as expected? [message #1690062] | Tue, 24 March 2015 18:08  |  |
| Eclipse User  |  |  |  |  | Hi,
 I have a question about the class org.eclipse.bpmn2.modeler.core.merrimac.dialogs.TextObjectEditor
 It looks to me that the multi-line feature is not working as expected?
 I try to create the editor widget like this:
  TextObjectEditor valueEditor = new TextObjectEditor(this, metaData, METADATA_VALUE);
 valueEditor.setMultiLine(true);
 valueEditor.createControl(this, "Value");
 But in this case the editor will be displayed as a single line editor with a heightHint of 100 but with no multi-line and no scroll bar.
 It only works if I create the editor like this:
 valueEditor.setStyle( SWT.MULTI | SWT.V_SCROLL);
 So I need to set the style 'SWT.MULTI' explicit.
 If I look into the sources of the method setMultiLine() it seems to be logical that the call
 is not enough and has no effect. Is this the desired behavior of that method?
 Maybe this is a side effect of the CData model extension? But setting the style to SWT.MULTI | SWT.V_SCROLL everything woks perfect.
 Ralph
| Re: TextObjectEditor - setMultiLine(true) not working as expected? [message #1690175 is a reply to message #1690062] | Wed, 25 March 2015 10:56   |  |
| Eclipse User  |  |  |  |  | Hey Ralph,
 Yep, looks like you're right (as usual
  ) I don't know what the heck I was thinking when I wrote that code. It looks like the test for multiline in createControl() is at fault:
	protected Control createControl(Composite composite, String label, int style) {
		createLabel(composite,label);
		if (testMultiLine && super.isMultiLineText()) {
			multiLine = true;
			style |= SWT.MULTI | SWT.V_SCROLL;
 I think it should look more like this:
		if (multiLine || (testMultiLine && super.isMultiLineText())) {
			multiLine = true;
 because of the setMultiLine() method:
	public void setMultiLine(boolean multiLine) {
		testMultiLine = false;
		this.multiLine = multiLine;
 What I wanted to accomplish was to allow custom property tabs to override the multiline setting from the ExtendedPropertiesAdapter's isMultiLine(), hence the use of the "testMultiLine" flag here.
 Please create a bugzilla to track this issue.
 Thanks!
 Bob
FUDForum. Page generated in 0.39107 seconds
