Home » Eclipse Projects » Advanced Scripting Environment (EASE) » Obsolete Ecore generated package extensions in EASE UI
Obsolete Ecore generated package extensions in EASE UI [message #1520290] Sun, 21 December 2014 04:56 Go to next message
Nicolas Rouquette is currently offline Nicolas RouquetteFriend
I noticed that there's been a significant refactoring of the EASE Core plugins.
In particular, there is no longer the "ScriptUIGraph" but there are still ScriptUIGraph-related extensions
in ease.ui's plugin.xml: these should be deleted.
   <extension point="org.eclipse.emf.ecore.generated_package">
      <!-- @generated ScriptUIGraph -->
      <package
            uri="http://scriptuigraph/1.0"
            class="org.eclipse.ease.ui.scriptuigraph.ScriptuigraphPackage"
            genModel="model/ScriptUIGraph.genmodel"/>
   </extension>
   <extension point="org.eclipse.emf.edit.itemProviderAdapterFactories">
      <factory
            class="org.eclipse.ease.ui.scriptuigraph.provider.ScriptuigraphItemProviderAdapterFactory"
            supportedTypes=
              "org.eclipse.emf.edit.provider.IEditingDomainItemProvider
               org.eclipse.emf.edit.provider.IStructuredItemContentProvider
               org.eclipse.emf.edit.provider.ITreeItemContentProvider
               org.eclipse.emf.edit.provider.IItemLabelProvider
               org.eclipse.emf.edit.provider.IItemPropertySource"/>
   </extension>
- Nicolas.
Re: Obsolete Ecore generated package extensions in EASE UI [message #1521430 is a reply to message #1520290] Sun, 21 December 2014 20:29 Go to previous messageGo to next message
Christian Pontesegger is currently offline Christian PonteseggerFriend
You are right, as before we would appreciate this as a gerrit commit Smile
Re: Obsolete Ecore generated package extensions in EASE UI [message #1522109 is a reply to message #1521430] Mon, 22 December 2014 05:40 Go to previous messageGo to next message
This is the simplest fix so I opened a bug per the instructions:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=455930
The status says "UNCONFIRMED".
I tried to push a commit to HEAD:refs/for/master as described in the gerrit instructions but I get an error: "invalid committer"
I'm missing something.
- Nicolas.
Re: Obsolete Ecore generated package extensions in EASE UI [message #1522276 is a reply to message #1522109] Mon, 22 December 2014 07:57 Go to previous messageGo to next message
Does the email address you provided along with your commit match with the address registered at eclipse.org? Might be a mismatch here. The commit should be signed by nicolas.rouquette@jpl.nasa.gov.
If the problem persists, please post the exact error message so we can have a closer look.
Re: Obsolete Ecore generated package extensions in EASE UI [message #1522845 is a reply to message #1522276] Mon, 22 December 2014 15:21 Go to previous messageGo to next message
Yes, there is a mismatch.
I updated my email address: nicolas.f.rouquette@jpl.nasa.gov on the Eclipse account page: https://dev.eclipse.org/site_login/myaccount.php
But Gerrit still uses my old address; so I tried to register a new email address here: https://git.eclipse.org/r/#/settings/contact
When I click on the link in the confirmation message, I get:
Server error
Invalid Token
Now what?
- Nicolas.
Re: Obsolete Ecore generated package extensions in EASE UI [message #1523032 is a reply to message #1522845] Mon, 22 December 2014 17:48 Go to previous message
Member
I pushed a fix to gerrit for bug 455930
Re: Obsolete Ecore generated package extensions in EASE UI [message #1690016 is a reply to message #1520290] Sun, 21 December 2014 20:29 Go to previous message
You are right, as before we would appreciate this as a gerrit commit :)
Re: Obsolete Ecore generated package extensions in EASE UI [message #1690019 is a reply to message #1690016] Mon, 22 December 2014 05:40 Go to previous message
- Nicolas.
Re: Obsolete Ecore generated package extensions in EASE UI [message #1690021 is a reply to message #1690019] Mon, 22 December 2014 07:57 Go to previous message
Does the email address you provided along with your commit match with the address registered at eclipse.org? Might be a mismatch here. The commit should be signed by mailto:nicolas.rouquette@xxxxxxxx.gov.
Re: Obsolete Ecore generated package extensions in EASE UI [message #1690022 is a reply to message #1690021] Mon, 22 December 2014 15:21 Go to previous message
I updated my email address: mailto:nicolas.f.rouquette@xxxxxxxx.gov on the Eclipse account page: https://dev.eclipse.org/site_login/myaccount.php
Server error
Invalid Token
Now what?
- Nicolas.
Re: Obsolete Ecore generated package extensions in EASE UI [message #1690023 is a reply to message #1522845] Mon, 22 December 2014 17:48 Go to previous message
Previous Topic:Shouldn't the EcoreModule initialize its selectionModule?
Next Topic:Shouldn't the EcoreModule initialize its selectionModule?
Current Time: Sat Dec 21 11:54:27 GMT 2024
Powered by FUDForum. Page generated in 0.05624 seconds
