Home » Modeling » EMF » [Teneo] automatically creation of database
[Teneo] automatically creation of database [message #1684003] |
Wed, 18 March 2015 08:40 |
Richard Meyer Messages: 40 Registered: June 2012 |
Member |
Hy all,
I use EMF Teneo to persistent EMF models into a PostgreSQL database.
I want that when I first time runs the project, it will create the database automaticlly.
Example:
URL = "jdbc:postgresql://127.0.0.1:5432/mydatabse"
I would like that if 'mydatabase' does not exits, Teneo should create it.
Therefor I use the property:
props.setProperty(Environment.HBM2DDL_AUTO, "create");
However this property seems to be ignored by Teneo because I get an
ERROR org.hibernate.engine.jdbc.spi.SqlExceptionHelper - FATAL: database "identifier" does not exist.
Many thanks for any advice
Richard
Properties props = new Properties();
props.setProperty(Environment.DRIVER, DRIVER);
props.setProperty(Environment.USER, USER);
props.setProperty(Environment.URL,"jdbc:postgresql://127.0.0.1:5432/mydatabse");
props.setProperty(Environment.PASS, PASS);
props.setProperty(Environment.DIALECT,
"org.hibernate.dialect.PostgreSQLDialect");
//create automatic creation of identifier database
// set a specific option
// see this page
// http://wiki.eclipse.org/Teneo/Hibernate/Configuration_Options
// for all the available options
props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_NON_CONTAINMENT,
"REFRESH,PERSIST,MERGE");
// use the joined inheritance mapping
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "JOINED");
dataStoreName = "IdentifierDataStore";
final HbDataStore dataStore = HbHelper.INSTANCE
.createRegisterDataStore(dataStoreName);
dataStore.setDataStoreProperties(props);
// Configure the EPackages used by this DataStore.
dataStore.setEPackages(new EPackage[] { IdentifierPackage.eINSTANCE });
// Initialize the DataStore. This sets up the Hibernate mapping and, in
// turn, creates the corresponding tables in the database.
try {
dataStore.initialize();
} finally {
// print the hibernate mapping
System.err.println(dataStore.getMappingXML());
try {
String uriStr = "hibernate://?" + HibernateResource.DS_NAME_PARAM
+ "=" + dataStoreName;
final URI uri = URI.createURI(uriStr);
ResourceSet resourceSet = new ResourceSetImpl();
res = resourceSet.createResource(uri);
res.load(Collections.EMPTY_MAP);
Iterator<?> it = res.getContents().iterator();
while (it.hasNext())
} catch (IOException e) {
throw new Error("IOException", e);
return true;
Re: [Teneo] automatically creation of database [message #1684191 is a reply to message #1684003] |
Wed, 18 March 2015 10:17 |
Hi Richard,
Yes.. Teneo uses Hibernate for this and afaik Hibernate does not create the schema:
http://blog.solidcraft.eu/2011/01/hibernate-hbm2ddl-wont-create-schema.html
This issue mentions some jpa 2.1 options, I have never tried it maybe you can:
https://hibernate.atlassian.net/browse/HHH-5665
In the Teneo testcases I 'manually' create the database using a jdbc connection before running the tests.
Btw, the Texo project can also be of interest if you are writing a server side app. With Texo you can use Eclipselink also:
http://wiki.eclipse.org/Texo
gr. Martin
On 18-03-15 09:40, Richard Meyer wrote:
> Hy all,
> Example: URL = "jdbc:postgresql://127.0.0.1:5432/mydatabse"
> However this property seems to be ignored by Teneo because I get an ERROR
> Richard
> // see this page
> try {
> } finally {
> try {
> while (it.hasNext()) {
> return true;
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Current Time: Fri Sep 27 00:28:50 GMT 2024
Powered by FUDForum. Page generated in 0.03995 seconds
