DiagramEditDomain cannot be cast to BpmnDiagramEditDomain??? [message #167428] |
Tue, 08 January 2008 22:12 |
I'm working on a tool integrating a GMF based editor and a TextEditor (code
is genereated from the Graph and shown in the TextEditor) in a
MultiPageEditor.
The integration is done, everything is working but often I receive the error
(when selecting an object within the graph or when deleting an object):
java.lang.ClassCastException:
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditDomain cannot be cast to
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditDomain
at
org.eclipse.stp.bpmn.diagram.actions.GroupAction.getSelectio n(GroupAction.java:504)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.getStructuredSelection(AbstractActionHandler.java:434)
at
org.eclipse.stp.bpmn.diagram.actions.GroupAction.refresh(Gro upAction.java:194)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.selectionChanged(AbstractActionHandler.java:387)
at
org.eclipse.ui.part.MultiPageSelectionProvider$1.run(MultiPa geSelectionProvider.java:109)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.ui.part.MultiPageSelectionProvider.fireEventChan ge(MultiPageSelectionProvider.java:107)
at
org.eclipse.ui.part.MultiPageSelectionProvider.fireSelection Changed(MultiPageSelectionProvider.java:89)
at
org.eclipse.ui.part.MultiPageEditorSite.handleSelectionChang ed(MultiPageEditorSite.java:452)
at
org.eclipse.ui.part.MultiPageEditorSite$2.selectionChanged(M ultiPageEditorSite.java:368)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer.flushSelectionEvents(DiagramGraphicalViewer.java:269)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer$1.run(DiagramGraphicalViewer.java:247)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
The error doesn't affect my editor, everything is working and I have
absolutely no idea where this comes from or how I could fix this...
especially cause there are no classes I created in the error message. Any
ideas? I could really need some help here!
Kind regards,
Markus
Re: DiagramEditDomain cannot be cast to BpmnDiagramEditDomain??? [message #167497 is a reply to message #167428] |
Wed, 09 January 2008 12:44 |
Hi, Markus,
This looks like a bug in the BPMN editor provided by the SOA Tools Project
(STP). Perhaps it is casting its net too wide in some extension point and
trying to contribute actions or other functionality to models outside of
its scope?
You might follow up with the eclipse.stp newsgroup.
Christian
> (code is genereated from the Graph and shown in the TextEditor) in a
> MultiPageEditor.
> error (when selecting an object within the graph or when deleting an
> object):
> to org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditDomain
> at
> at
> at
> at
> at
> at
-----8<-----
FUDForum. Page generated in 0.03486 seconds
