Re: 64-bit Linux [message #997349 is a reply to message #927430] |
Sun, 06 January 2013 18:49 |
Same here. I looked into building my own, but, frankly, it seemed like a lot of work with an uncertain outcome (in particular the dependencies to the native html rendering engine make me worry that I get the thing to compile, but the editors being unusable).
Is the EPF build even automated? I have not seen it at https://hudson.eclipse.org/hudson/
*Bump* [message #1068185 is a reply to message #997349] |
Fri, 12 July 2013 14:48 |
Just wondering - as time passes, and almost all machines have >3GB, I see fewer and fewer 32bit Linux machines. A 64bit built would be greatly appreciated.
Re: 64-bit Linux [message #1792811 is a reply to message #1728851] |
Tue, 24 July 2018 10:11 |
Javier Alcala wrote on Thu, 07 April 2016 21:25The solution that worked for me was:
1. get a 32 bits java VM (download form otn.oracle.com)
How did you solved the rich test editing? Using a recent xulrunner? downloading an ancient Firefox version?
FUDForum. Page generated in 0.06580 seconds
