Home » Modeling » GMF (Graphical Modeling Framework) » How to rotate a border item
Re: How to rotate a border item [message #162479 is a reply to message #162003] |
Fri, 23 November 2007 19:13 |
Cherie Revells Messages: 299 Registered: July 2009 |
Jaap, Jacques:
The figure for the connection handles on shapes also changes based on
the side of the shape the connection handles appear on. I solved the
initialization problem discussed in the other thread in the connection
handles, by putting the locator.relocate() call in the border item
figure's validate() method. It seemed sense to put it here to me as
this is where the layout of the figure is normally triggered. I'm not
sure if this will work for your scenario.
As for rotating a figure, there is a rotate() method on the
org.eclipse.draw2d.Graphics class. This method is implemented in the
SWTGraphics class, but not in GMF's ScaledGraphics class. I would
suggest you create a bugzilla to add this support to GMF's
ScaledGraphics class, or better yet, try it yourself first and include
your results in the bugzilla. I'm not sure if there are any
implications to this or if it was just overlooked in GMF.
Cherie
Jaap Reitsma wrote:
> Hi Jacques,
> The thread you refer to describes indeed the same issue. What I am looking
> for is a solution for rotating the figure, and also for solving the
> initialization problem that you also seem to have.
> Kind regards,
> Jaap
> "Jacques LESCOT" <jacques.lescot@anyware-tech.com> wrote in message
> news:fi3a9r$t99$1@build.eclipse.org...
>> There is an existing thread titled "how to change the border item's
>> direction?" about this issue that could help you.
>> Jacques
>> Jaap Reitsma a écrit :
>>> Hi all,
>>> What is the best way to a rotate border item, depending on its position
>>> w.r.t. the parent?
>>> The situation: Our border item is a triangle, created with a Polygon. The
>>> triangle is sitting on the border of a rectangle and should always point
>>> inwards into the rectangle. Actually we gave it an offset
>>> (borderlocator.setBorderOffset()) so it appears pointing thru the border.
>>> A trick that works is to create four triangles, for each side one. Use a
>>> StackLayout as the LayoutManager and in the editpart.refreshBounds()
>>> determine which side the item is sitting
>>> (getBorderItemLocator().getCurrentSideOfParent().) and then set one of
>>> the four triangles to visible.
>>> But I am thinking of using a transformation to rotate the polygone (or
>>> some other shape), and to spare me the hassle with the StackLayout. Is
>>> that possible, and if so, how?
>>> Kind regards,
>>> Jaap Reitsma
Re: How to rotate a border item [message #165460 is a reply to message #162479] |
Fri, 14 December 2007 15:32 |
Jaap Reitsma Messages: 69 Registered: July 2009 |
Member |
Hi Cherie,
How did you do that with the invalidate()? With the debugger it looks as if
the position with reference to its border is still unknown. Only after
moving the border item the position (side) is determined correctly....
Kind regards,
Jaap
"Cherie Revells" <crevells@ca.ibm.com> wrote in message
news:fi78uj$ap0$1@build.eclipse.org...
> Jaap, Jacques:
> The figure for the connection handles on shapes also changes based on the
> figure's validate() method. It seemed sense to put it here to me as this
> is where the layout of the figure is normally triggered. I'm not sure if
> SWTGraphics class, but not in GMF's ScaledGraphics class. I would suggest
> you create a bugzilla to add this support to GMF's ScaledGraphics class,
> or better yet, try it yourself first and include your results in the
> bugzilla. I'm not sure if there are any implications to this or if it was
> Regards,
> Cherie
> Jaap Reitsma wrote:
>> Hi Jacques,
>> looking for is a solution for rotating the figure, and also for solving
>> the initialization problem that you also seem to have.
>> Kind regards,
>> Jaap
>>> Jacques
>>> Jaap Reitsma a
Re: How to rotate a border item [message #170927 is a reply to message #161946] |
Thu, 31 January 2008 15:55 |
Member |
Hi all,
At last I have fond a solution that rotates my bordered triangle (always
pointing inwards in a container) as well as being initialized properly when
opening the diagram. In my first attempt I used
MyTriangleEditPart.refreshBounds() to manipulate the orientation. Although
it works when dragging the triangle around the container, it does not get
initialized properly as the refreshBounds of the bordered item is called
when the layout of the parent has not been done yet.
The seemingly elegant solution is to hook into the layout of the border item
container, i.e. the parent of my bordered triangle figure. The code I have
used follows below:
/* (non-Javadoc)
* @see
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt#activate()
public void activate() {
IBorderItemLocator locator = getBorderItemLocator();
if (locator instanceof BorderItemLocator) {
((BorderItemLocator)locator).setBorderItemOffset(new Dimension(8,
8));
IFigure figure = getFigure();
if (figure instanceof BorderedNodeFigure) {
BorderedNodeFigure bnf = (BorderedNodeFigure)figure;
IFigure bicf = bnf.getBorderItemContainer();
bicf.addLayoutListener(new LayoutListener.Stub() {
public void postLayout(IFigure container) {
getBorderItemLocator().relocate(getFigure());
int position =
getBorderItemLocator().getCurrentSideOfParent();
int rotation = 0;
switch (position) {
case PositionConstants.WEST:
break;
case PositionConstants.NORTH:
rotation = 90;
break;
case PositionConstants.EAST:
rotation = 180;
break;
case PositionConstants.SOUTH:
rotation = 270;
break;
default:
break;
getPrimaryShape().setRotationInDegrees(rotation);
super.activate();
The setRotationInDegrees is a method in my custom RotableScalablePolygon
which is actually a copy of the implementation of the inner figure generated
by GMF when using a scalable polygon as figure.
Kind Regards,
Jaap
"Jaap Reitsma" <jaap.reitsma@telin.nl> wrote in message
news:fi2co4$cq4$1@build.eclipse.org...
> Hi all,
> w.r.t. the parent?
> (getBorderItemLocator().getCurrentSideOfParent().) and then set one of the
> Kind regards,
> Jaap Reitsma
Re: How to rotate a border item [message #668318 is a reply to message #170927] |
Thu, 05 May 2011 07:42 |
Rahma Messages: 7 Registered: February 2011 |
Hi Jaap,
Can you please Help me,
I Have the same problem, but I can't understand your solution:
1) Can you, give me the code of the method setRotationInDegrees and in which class is placed?
2)In which class exactly is placed the following code ?
* (non-Javadoc)
* @see
Thanks.
Rahma
[Updated on: Thu, 05 May 2011 07:43] Report message to a moderator
Current Time: Thu Dec 26 12:50:09 GMT 2024
Powered by FUDForum. Page generated in 0.02794 seconds
