| "Invalid registry object" prevents RCP application to start afte rmigration from Eclipse 4 [message #1505998] |
Wed, 10 December 2014 08:45  |
I 'm currently migrating my RCP application from Eclipse 4.3 to Eclipse 4.4.1.
The application is not starting with a packaged build. It starts from Development environment and even in Remote Debug on a built applications.
There is this stack in log:
!ENTRY org.eclipse.osgi 4 0 2014-12-10 13:28:37.773
!MESSAGE An error occurred while automatically activating bundle org.eclipse.emf.ecore (643).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation$Activator.start() of bundle org.eclipse.emf.ecore.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:391)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
at org.eclipse.e4.ui.internal.workbench.GenericMApplicationElementFactoryImpl$MApplicationElementClassToEClass.<init>(GenericMApplicationElementFactoryImpl.java:136)
at org.eclipse.e4.ui.internal.workbench.GenericMApplicationElementFactoryImpl$MApplicationElementClassToEClass.<init>(GenericMApplicationElementFactoryImpl.java:112)
at org.eclipse.e4.ui.internal.workbench.GenericMApplicationElementFactoryImpl.<init>(GenericMApplicationElementFactoryImpl.java:71)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.<init>(ModelServiceImpl.java:121)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:505)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:210)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:601)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.bonitasoft.studio.application.BonitaStudioApplication.start(BonitaStudioApplication.java:90)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: org.eclipse.core.runtime.InvalidRegistryObjectException: Invalid registry object
at org.eclipse.core.internal.registry.RegistryObjectManager.basicGetObject(RegistryObjectManager.java:273)
at org.eclipse.core.internal.registry.RegistryObjectManager.getObject(RegistryObjectManager.java:263)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getConfigurationElement(ConfigurationElementHandle.java:26)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.getName(ConfigurationElementHandle.java:99)
at org.eclipse.emf.ecore.plugin.GeneratedPackageRegistryReader.readElement(GeneratedPackageRegistryReader.java:53)
at org.eclipse.emf.ecore.plugin.RegistryReader.internalReadElement(RegistryReader.java:118)
at org.eclipse.emf.ecore.plugin.RegistryReader.readRegistry(RegistryReader.java:88)
at org.eclipse.emf.ecore.plugin.EcorePlugin$ExtensionProcessor.internalProcessExtensions(EcorePlugin.java:917)
at org.eclipse.emf.ecore.plugin.EcorePlugin$ExtensionProcessor.access$0(EcorePlugin.java:868)
at org.eclipse.emf.ecore.plugin.EcorePlugin$Implementation.start(EcorePlugin.java:678)
at org.eclipse.emf.common.EMFPlugin$OSGiDelegatingBundleActivator.start(EMFPlugin.java:201)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
... 54 more
Root exception:
While searching on a little on Internet, it seems that this error occurs when an extension point has been registered then unproperly unregistered.
How can I check release/unrelease of elements?
It seems that the extension points in question is org.eclipse.emf.ecore.generated_package.
I have several extensions for this extension point and also a lot of plugins in my Target Platform. How can I determine from which bundle the failing one is contributed? (although when I try access the ConfigurationElement name for instance, I have this exception)
Can it be an EMF issue? In this case, I will post on the EMF newsgroup.
EDIT: I don't have this stack anymore when I patch some plugins just adding some System.out for investigations. I don't know how to investigate on my issue :s
Thanks by advance for any help,
[Updated on: Wed, 10 December 2014 09:12] by Moderator
FUDForum. Page generated in 0.03282 seconds
