Tycho throwing a NoClassDefFoundError [message #1653745] |
Fri, 06 March 2015 11:11 |
Thomas Elskens Messages: 159 Registered: September 2014 Location: Brussels - Belgium |
When doing a Tycho build, Tycho stumbles over one my test plugins, throwing a no NoClassDefFoundError over javafx/collections/FXCollections, as follows :
Running be.groups.portfolio.service.codelist.CodelistItemsTest
Tests run: 3, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.093 sec <<< FAILURE! - in be.groups.portfolio.service.codelist.CodelistItemsTest
testItemsLength(be.groups.portfolio.service.codelist.CodelistItemsTest) Time elapsed: 0.064 sec <<< ERROR!
java.lang.NoClassDefFoundError: javafx/collections/FXCollections
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:389)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at be.groups.portfolio.service.codelist.CodelistItems.getLabels(CodelistItems.java:69)
at be.groups.portfolio.service.codelist.CodelistItemsTest.testItemsLength(CodelistItemsTest.java:68)
unknownLanguageShouldReturnFrench(be.groups.portfolio.service.codelist.CodelistItemsTest) Time elapsed: 0.001 sec <<< ERROR!
at be.groups.portfolio.service.codelist.CodelistItemsTest.unknownLanguageShouldReturnFrench(CodelistItemsTest.java:84)
Needless to say, I have neither compiling issues nor problems to launch the tests from inside the IDE.
I have no idea where as to look for this problem, any ideas ... ?
Thomas Elskens
Re: Tycho throwing a NoClassDefFoundError [message #1653937 is a reply to message #1653745] |
Fri, 06 March 2015 13:02 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
So what version of java is the build running on? Is it running on the
same computer you develop? e.g. when you run the build on a linux server
make sure you run with OracleJDK and/or an OpenJDK you downloaded
yourself because the stock one from linux distros does not holds JavaFX
Tom
On 06.03.15 12:11, Thomas Elskens wrote:
> Hello,
> Quote:
>> at
>> at
>> at
>> at
>> at java.lang.ClassLoader.loadClass(Unknown Source)
>> at
>> at
>> at
>> at
> Thomas Elskens
FUDForum. Page generated in 0.04508 seconds
