Home » Eclipse Projects » Eclipse Platform » preprocessor plugin
preprocessor plugin [message #163285] Fri, 28 November 2003 08:20 Go to next message
Hello
I found that standart "cpp" preprocessor can parse Java files.
I checked source code for it - seems so be simple enough, so i'm going
to develop the plug-in for C-like pre-processing in Java files. Right
now i thinking in this way:
When statring build-in parser for syntax check, get input stream of file
to parse, then run the pre-processor, get output stream and pass it to
the Eclipse's lexer (or whatever it uses). This way Eclipse will be able
to parse the result file, and show the syntax/grammar's errors. For
correct mapping of found error to original file (in case if they occures
inside the case conditions or macros) i will need to have a way to get
the line numbers for errors and map it to actual lines of original file
with pre-processor statements. So the plug-in will be a "layer" between
the UI for the graphical representation of Java file and the Eclipse's
lexer.
Can anybody suggest me anything regarding the thoughts given above?
Re: preprocessor plugin [message #163438 is a reply to message #163285] Fri, 28 November 2003 21:04 Go to previous messageGo to next message
What benefit is a preprocessor when you can use AspectJ?
-d
"Eugeny N Dzhurinsky" <eugenydzh@jdevelop.com> wrote in message
news:bq7hti$tcc$1@eclipse.org...
> Hello
> lexer.
Re: preprocessor plugin [message #163488 is a reply to message #163285] Sat, 29 November 2003 05:02 Go to previous messageGo to next message
Originally posted by: crscca.bol.net.n
Eugene did u try the eclipse cdt? does it already solve this issue?cann it
be resused?
Well I dont know about aspectj but a pre-processor could be useful if you
are in some rare case writing the same code again and again and for some
reson or the other you are not able to encapsulate it beyond a point using
OOP.
So as an alternative you end up developing a kind of template for various
pieces of code. If this is the purpose a C++ style preprocesor might be a
good idea.
As an extension or add on see if you can get the preprocessor to read
inputs from propertyfiles for "define" values and also run a loop on
various property/xml files as specified in one particular central
controller property/xml file. Could be useful under those circumstances.
This would eliminate some of the tedius apects of even preprocessor
statements.
Eugeny N Dzhurinsky wrote:
> Hello
> lexer.
Re: preprocessor plugin [message #266885 is a reply to message #163488] Fri, 13 August 2004 12:39 Go to previous message
Originally posted by: jbacon_FAKE_.magmic_FAKE_.com
Did anyone ever get around to writing a plugin for this? I am using
Antenna (antenna.sourceforge.net) for my J2ME development in Eclipse and
I have ifdef's all over the place which makes Eclipse's parsing choke.
I'd LOVE a plugin that would handle a preprocessor. I don't have the
time to spend on it but if someone else did that would ROCK.
> be resused?
> OOP.
> good idea.
> statements.
>>Hello
>>lexer.
Previous Topic:Eclipse 3.0.0 & task view
Next Topic:Java Preprocessor
Current Time: Fri Nov 07 16:07:35 EST 2025
Powered by FUDForum. Page generated in 0.03761 seconds
