Home » Eclipse Projects » e(fx)clipse » Running OSGi Console(Cannot Run OSGi Console In Deployed Product)
Running OSGi Console [message #1632465] Tue, 24 February 2015 09:40 Go to next message
Christian Ora is currently offline Christian OraFriend
Hi there,
In my deployed efxclipse product, the osgi console simply doesn't show up on product startup. The "-console" argument is added. The plugins:
org.eclipse.equinox.console
org.apache.felix.gogo.command
org.apache.felix.gogo.runtime
org.apache.felix.gogo.shell
are existant in plugins-folder of the exported product. The default console doesn't show up too, although the argument "-consoleLog" is added.
I'm running the appplication on win 7 with java 1.8_20. Targetplatform is Luna with efxclipse 1.2 .
Any hints on this issue ?
Kind regards
Re: Running OSGi Console [message #1632701 is a reply to message #1632465] Tue, 24 February 2015 12:32 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph KeimelFriend
IIRC you need to use -console to use the OSGi console.
Re: Running OSGi Console [message #1632710 is a reply to message #1632701] Tue, 24 February 2015 12:40 Go to previous messageGo to next message
I did. I was just saying that the default console doesn't show up too. Smile
Re: Running OSGi Console [message #1632758 is a reply to message #1632710] Tue, 24 February 2015 13:12 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
Is org.eclipse.equinox.console part of your product? Is it added in one of your product features?
Re: Running OSGi Console [message #1632765 is a reply to message #1632758] Tue, 24 February 2015 13:16 Go to previous messageGo to next message
It is. As well as:
Has anyone tried to run a deployed efxclipse product with an osgi console, yet ?
Re: Running OSGi Console [message #1633041 is a reply to message #1632765] Tue, 24 February 2015 16:43 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
How are you launching the exported product? Did you use the
javafx-packager?
Please note that to pass a on command parameters you need to make the
javafx-packager aware of them.
Tom
On 24.02.15 14:16, Christian Ora wrote:
> It is. As well as:
> console, yet ?
Re: Running OSGi Console [message #1634297 is a reply to message #1633041] Wed, 25 February 2015 07:38 Go to previous messageGo to next message
I built it with maven and deployed it with the build.xml ant script. So i guess the product ist launched via equinox ?
Re: Running OSGi Console [message #1634305 is a reply to message #1634297] Wed, 25 February 2015 07:43 Go to previous messageGo to next message
Ok so this means you used the javafx-packager application! You need to
modify the build.xml file to make the native binary pass on the -console
-consoleLog flags!
See
http://docs.oracle.com/javafx/2/deployment/javafx_ant_task_reference.htm#CIACICCF
and
http://docs.oracle.com/javafx/2/deployment/javafx_ant_task_reference.htm#CIAHJIJG
Tom
Re: Running OSGi Console [message #1634556 is a reply to message #1634305] Wed, 25 February 2015 10:28 Go to previous messageGo to next message
Thank you for pointing me to this reference. I always felt that i was missing something.
Since "-console" and "-consoleLog" are program/application arguments. I assume the build.xml should look like this
<fx:application id="fxApplication" name="sandbox" mainClass="org.eclipse.equinox.launcher.Main" toolkit="swing">
<param name = "consoleLog"/>
<param name = "console"/>
</fx:application>
I tried several variations of this with "-console" & "-consoleLog" also tried the fx:argument and argument tag (basically the same i guess?). Neither brought the console to show up.
Btw. the eclipse.ini of the exported product looks like this
-nosplash
-consoleLog
-console
-vmargs
-Dosgi.framework.extensions=org.eclipse.fx.osgi
Re: Running OSGi Console [message #1634574 is a reply to message #1634556] Wed, 25 February 2015 10:36 Go to previous messageGo to next message
> missing something.
> </fx:application>
> -nosplash
> -consoleLog
> -console
> -vmargs
Noone is looking at this file, only the eclipse launcher would have but
the exe you see is generated by the javafx packager. Dod you try jvmArgs
I can remember having seen them working.
Tom
Re: Running OSGi Console [message #1634926 is a reply to message #1634574] Wed, 25 February 2015 14:26 Go to previous messageGo to next message
I added
<fx:platform>
	<fx:jvmarg value="-Xms0m"/>
	<fx:jvmarg value="-Xmx0m"/>
</fx:platform>
which should produce an Error(Couldn't create Java Virtual Machine),
but after deploying via build.xml the applications starts as usual.
I also tried to monitor the jvm of the deployed product via jps, to see if jvm args(with proper values) are passed, but it said that the process information was unavailable.
Also , when i call Platform.getCommandlineArgs() or Application.getParameters(), the List is empty. Do you think it is possible that there might be a bug ?
[Updated on: Wed, 25 February 2015 14:26]
Report message to a moderator
Re: Running OSGi Console [message #1634953 is a reply to message #1634926] Wed, 25 February 2015 14:43 Go to previous messageGo to next message
At least I know I used this on OS-X if I remember correctly. I'll give
it a try on os-x to see if it works.
Naturally you are most likely better of testing this with a simple
JavaFX application and once you are confident it works there as
advertised you then try applying this to e4+javafx.
Tom
On 25.02.15 15:26, Christian Ora wrote:
> I added <fx:platform>
> </fx:platform>
> if jvm args are passed, but it said that the process information was
> unavailable.
Re: Running OSGi Console [message #1634962 is a reply to message #1634926] Wed, 25 February 2015 14:49 Go to previous messageGo to next message
I think I only tried:
<fx:platform>
<property name="purpose" value="sample value"/>
</fx:platform>
So you should be able to check them with
System.getProperties().getProperty("purpose").
Tom
> </fx:platform>
> unavailable.
Re: Running OSGi Console [message #1667950 is a reply to message #1634962] Thu, 12 March 2015 09:05 Go to previous messageGo to next message
A small update: It is possible to pass at least VM-Arguments by modifying the package.cfg file in the deployed product:
app.mainjar=plugins\org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
app.version=1.0
app.id=fxApplication
app.preferences.id=fxApplication
app.mainclass=org/eclipse/equinox/launcher/Main
jvmarg.1= -vmargument
app.classpath=
It took me quite long to figure that out, so i though it might be helpful to mention it here.
[Updated on: Thu, 12 March 2015 10:10]
Re: Running OSGi Console [message #1668381 is a reply to message #1667950] Thu, 12 March 2015 13:06 Go to previous messageGo to next message
Thanks - from my understanding that's what the ant statements should
have produced, not?
Tom
> app.version=1.0
> app.classpath=
> helpful to mention it here,
Re: Running OSGi Console [message #1678496 is a reply to message #1668381] Mon, 16 March 2015 08:06 Go to previous message
At least my attempts to modify the ant script did fail, no matter if i used property, param, argument or jvmarg.
pckage.cfg stayed:
app.version=1.0
app.classpath=
But since i'm not familiar with ant, it might be possible that i put the statements/tags in wrong places, allthough tha ant script didn't complain.
Previous Topic:e(fx)clipse at EclipseCon NA 2015
Next Topic:I have installed the most recent e(fx)clipse AinO packages and it gives me this errors
Current Time: Wed Feb 05 04:44:18 GMT 2025
Powered by FUDForum. Page generated in 0.04529 seconds
