Home » Modeling » Compare » Diff include change to EStructuralFeature ID
Diff include change to EStructuralFeature ID [message #1624037] Thu, 19 February 2015 14:06 Go to next message
Kyle B is currently offline Kyle BFriend
I am currently using the Default implementations of EMFCompare match/diff engine to compare two EPackageRegistry objects for differences. This is being used to detect model changes. One issue I have run into is if a EClass's EStructuralFeature list is reordered, the EMFCompare matcher/diff engine does not catch this change.
Can I extend EMFCompare to include this change?
Thanks!
Re: Diff include change to EStructuralFeature ID [message #1624126 is a reply to message #1624037] Thu, 19 February 2015 15:30 Go to previous messageGo to next message
Axel RICHARD is currently offline Axel RICHARDFriend
Member
Which version of EMF Compare do you use ?
Axel Richard
Obeo
Re: Diff include change to EStructuralFeature ID [message #1624294 is a reply to message #1624126] Thu, 19 February 2015 17:47 Go to previous messageGo to next message
Currently 2.1.2
Re: Diff include change to EStructuralFeature ID [message #1625247 is a reply to message #1624294] Fri, 20 February 2015 08:43 Go to previous message
Member
I recommend you to use the latest EMF Compare stream (3.x). You can download it via http://download.eclipse.org/modeling/emf/compare/updates/releases/latest
Axel Richard
Obeo
Previous Topic:Extension support for EMFCompareStructureMergeViewer
Next Topic:[EMF Compare] Equality Helper not used in match phase
Current Time: Thu Dec 26 12:11:33 GMT 2024
Powered by FUDForum. Page generated in 0.03800 seconds
