Home » Archived » Eclipse Process Manager (Stardust) » Stardust_Testing_Embedded_Spring_2.1.0 extended
Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1616163] Sat, 14 February 2015 11:14 Go to next message
kayvan jam is currently offline kayvan jamFriend
Member
hi all ,
I get the Stardust_Testing_Embedded_Spring_2.1.0 from folowing link:
https://www.eclipse.org/forums/index.php/m/1609809/#msg_1609809http://
and model my model and when test this test getting exception , plz guide me where's my fault and my 2nd question is if i wanna extend this program without spring-test then what suppose to do?
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1616340 is a reply to message #1616163] Sat, 14 February 2015 14:04 Go to previous messageGo to next message
Member
please any idea could be effective !!!
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1616486 is a reply to message #1616340] Sat, 14 February 2015 16:23 Go to previous messageGo to next message
Member
my problem solved , i revised my model and worked but my 2nd Q remined , any example exist about spring embedded without spring-test that exist spring bean app ,
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1617848 is a reply to message #1616486] Sun, 15 February 2015 14:47 Go to previous messageGo to next message
Robert Emsbach is currently offline Robert EmsbachFriend
Kayvam,
please see https://wiki.eclipse.org/STP/Stardust/KnowledgeBase#Embedded_Usage
Rob
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1617854 is a reply to message #1617848] Sun, 15 February 2015 14:54 Go to previous messageGo to next message
Member
thanks rob ,
i saw these but i want full example in embedded_usage that dont use spring test instead using bean app , for example exist help desk senario wrote in spring bean emphasis on without spring-test environment
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1617865 is a reply to message #1617854] Sun, 15 February 2015 15:00 Go to previous messageGo to next message
Kayvam,
you requirement is not clear to me.
You want to invoke a spring bean from within a process? You want to start a process from within a Spring bean?
https://wiki.eclipse.org/Stardust/Knowledge_Base/API/ExamplesofAPIUsage/StartProcess
maybe?
Or you want to bootstrap the whole engine without a WAR/tomcat, only in a standalone spring container?
Best regards
Robert
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1617871 is a reply to message #1617865] Sun, 15 February 2015 15:06 Go to previous messageGo to next message
Member
i want to bootstrap the whole engine without a WAR/tomcat, only in a standalone spring container as in example
https://www.eclipse.org/forums/index.php/t/970086/
as Rajkumar Dangi wrote this example : Stardust_Testing_Embedded_Spring_2.1.0.zip ofcourse without spring-test section.
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1617877 is a reply to message #1617871] Sun, 15 February 2015 15:12 Go to previous messageGo to next message
Kayvan,
have a look at carnot-spring-context.xml and carnot-spring-ds-context.xml in /portal811/src/main/resources.
Depending on whcih componenets you want to use, e.g. DocumnetManagementService, also checkout the context files under src\main\webapp\WEB-INF\config\ipp\spring
Best regards
Rob
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1617878 is a reply to message #1617877] Sun, 15 February 2015 15:15 Go to previous messageGo to next message
Member
from where? plz give me address
Re: Stardust_Testing_Embedded_Spring_2.1.0 extended [message #1617895 is a reply to message #1617878] Sun, 15 February 2015 15:28 Go to previous message
Kayvan,
for instance create a WAR project using the Maven archetype.
Inside that project you find all those files.
Rob
Previous Topic:Help for creating stardust standalone engine
Next Topic:unexpected work list query result
Current Time: Sat Dec 21 16:56:37 GMT 2024
Powered by FUDForum. Page generated in 0.03952 seconds
