Home » Language IDEs » ServerTools (WTP) » images
images [message #161556] Wed, 22 February 2006 07:53 Go to next message
Zohar Amir is currently offline Zohar AmirFriend
I have a servlet that does some XSLT to produce an HTML. This HTML document
contains references to images. I tried putting the images in the WebContent
directory, but they could not be loaded with the HTML. I then tried loading
them explicitly (http://myserver/context/image.gif), but instead of getting
them, the servlet was invoked (it's doGet method).
What should I do to be able to use images?
Zohar.
Re: images [message #161670 is a reply to message #161556] Wed, 22 February 2006 20:58 Go to previous messageGo to next message
Kaj Kandler is currently offline Kaj KandlerFriend
Member
Zohar wrote:
> Zohar.
This sounds like a tomcat/web-server configuration problem (most likely
nothing to do with Eclipse).
You need to put your images outside the context you serve your JSP from,
for example
http://myserver/images/image.gif
http://myserver/context/mypage
good luck
K<o>
Re: images [message #161720 is a reply to message #161670] Thu, 23 February 2006 07:23 Go to previous message
Using WTP, how do I put the images in http://myserver/images/image.gif ?
"Kaj Kandler" <KajKandler@conficio.com> wrote in message
news:dtij9s$i97$1@utils.eclipse.org...
> Zohar wrote:
>> Hi,
>> document
>> WebContent
>> loading
>> getting
>> Thanks,
>> Zohar.
> for example
> good luck
> K<o>
Previous Topic:Publishing to Tomcat .. keeps on running
Next Topic:Classpath Compile problem
Current Time: Thu Nov 07 12:11:22 GMT 2024
Powered by FUDForum. Page generated in 0.09583 seconds
