Home » Language IDEs » ServerTools (WTP) » Update from within wtp-all-in-one-sdk-1.0-linux-gtk effects only emf
Update from within wtp-all-in-one-sdk-1.0-linux-gtk effects only emf [message #161458] Tue, 21 February 2006 15:04 Go to next message
an update from within wtp-all-in-one-sdk-1.0-linux-gtk, which is
eclipse 3.1.1 platform does not include an update to eclipse 3.1.2
Is this behaviour intended?
Wolfgang
Re: Update from within wtp-all-in-one-sdk-1.0-linux-gtk effects only emf [message #161564 is a reply to message #161458] Wed, 22 February 2006 03:04 Go to previous messageGo to next message
On Tue, 21 Feb 2006 15:04:24 -0500, Johannes Wolfgang Woger <jwwoger@chello.at> wrote:
> Wolfgang
This should work, but it is a funtion of the base Eclipse itself, not WTP.
And, its a little different than the process of updating WTP.
If you already have 3.1.1 installed (via the all in one zip), you should be able to use simply the
Update Manager choice of "check for updates of existing features". And ... that should find updates
for 3.1.2 Eclipse, and EMF update. It would not find any for GEF or JEM as those did not change.
It also would not find for WTP 1.0.1, for different reasons. I will be publishing directions for that soon.
If you find it does not work, you might help contribute by doing some "pure" tests (a fresh 3.1.1
install first) then try the "check for updates to existing features". If that does not work, its bug-worthy.
Re: Update from within wtp-all-in-one-sdk-1.0-linux-gtk effects only emf [message #161579 is a reply to message #161564] Wed, 22 February 2006 05:50 Go to previous messageGo to next message
I now installed a fresh pure (SDK-3.1.1-linux-gtk.tar.gz) eclipse.
A search for updates to existing feature(s) said: "No update for the
currenty installed feature(s) try again later"
I am using Suse9.2, jdk1.5
Re: Update from within wtp-all-in-one-sdk-1.0-linux-gtk effects only emf [message #161647 is a reply to message #161579] Wed, 22 February 2006 12:39 Go to previous messageGo to next message
On Wed, 22 Feb 2006 05:50:03 -0500, Johannes Wolfgang Woger <jwwoger@chello.at> wrote:
Well, I haven't tried it myself, but I THINK that would be a
bug against the platform update component ... I'b be interested in
what they say!
Re: Update from within wtp-all-in-one-sdk-1.0-linux-gtk effects only emf [message #161807 is a reply to message #161647] Thu, 23 February 2006 14:48 Go to previous message
> what they say!
Some coments in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=123162
already describe the problem.
http://www.eclipse.org/eclipse/platform-releng/updatesfor3.1 .1.html
provides an alternate update procedure which actually solved the problem.
Wolfgang
Previous Topic:Eclipse Tomcat problem
Next Topic:Connection pooling
Current Time: Wed Apr 16 12:09:56 EDT 2025
Powered by FUDForum. Page generated in 0.02648 seconds
