Home » Language IDEs » ServerTools (WTP) » Publishing to Tomcat .. keeps on running
Publishing to Tomcat .. keeps on running [message #161094] Fri, 17 February 2006 22:31 Go to next message
Originally posted by: pgupta.intercall.com
I was following earlier posts on web services and someone mentioned that
i needed to manually copy over the generated classes from the meta folder
to the web content folder of my web project. i did that and then i hit
refresh so that Eclipse would pick up the new classes. The progress window
says Publishing to Tomcat v5.5 Server and then it just takes forever to
complete. Does anyone else have any similar issue to this? Please share
your solutions.
Re: Publishing to Tomcat .. keeps on running [message #161133 is a reply to message #161094] Sat, 18 February 2006 05:41 Go to previous messageGo to next message
Originally posted by: jazeltine.sbcglobal.net
pgupta@intercall.com (Praful Gupta) wrote in
news:6f9326a6f261513aaf325faabac2ed0d$1@www.eclipse.org:
> that
> folder to the web content folder of my web project. i did that and
> then i hit refresh so that Eclipse would pick up the new classes. The
> progress window says Publishing to Tomcat v5.5 Server and then it just
> takes forever to complete. Does anyone else have any similar issue to
> this? Please share your solutions.
> Thanks
Let me guess, you are using WTP 1.0? If so, try falling back to WTP 0.7.1.
Jim
Re: Publishing to Tomcat .. keeps on running [message #161421 is a reply to message #161133] Tue, 21 February 2006 19:14 Go to previous messageGo to next message
Originally posted by: a.b.com
Do we conclude from your reply that this is a known problem with WTP 1.0?
I just waited for about 15 minutes at 100% CPU with ONLY Eclipse running,
saying that it is "Publishing to Tomcat" and the project has only one
trivial servlet defined. To add insult to injury I hadn't even asked it to
run the servlet!!!
What on earth can it be doing with all that CPU? And why does it need to
publish so often? Intutively, I would expect publishing to occur only when
I try to run something.
Re: Publishing to Tomcat .. keeps on running [message #161507 is a reply to message #161421] Wed, 22 February 2006 04:28 Go to previous messageGo to next message
"Chris Gage" <a@b.com> wrote in news:dtforc$fda$1@utils.eclipse.org:
> 1.0?
> running, saying that it is "Publishing to Tomcat" and the project has
> only one trivial servlet defined. To add insult to injury I hadn't
> even asked it to run the servlet!!!
> to publish so often? Intutively, I would expect publishing to occur
> only when I try to run something.
If you look back at threads that were put up towards the end of December
and early January, there were several issues that were found, this being
one of them.
HTH
Jim
Re: Publishing to Tomcat .. keeps on running [message #161674 is a reply to message #161507] Wed, 22 February 2006 22:47 Go to previous message
Unfortunately I cannot see any posts earlier than 13th January, so I'll take
your word for it.
Previous Topic:JSP Client
Next Topic:images
Current Time: Sat Nov 09 05:22:00 GMT 2024
Powered by FUDForum. Page generated in 0.02854 seconds
