Home » Archived » EPF » Active Images(How to insert active images in published sites)
Active Images [message #1611259] Wed, 11 February 2015 08:50 Go to next message
Bruno Di Giandomenico is currently offline Bruno Di GiandomenicoFriend
Hello, this might be an item which has already been asked and answered, but I do not seem to be able to find any answer, maybe I am using the wrong terms.
I am trying to insert images which can have embedded links to other pages of the published site. I believe OpenUp does it, and other sites I have seen can do it, but I do not understand the procedure for doing it.
Where can I find some help ?
Thanks in advance
Bruno
Re: Active Images [message #1653658 is a reply to message #1611259] Fri, 06 March 2015 10:23 Go to previous messageGo to next message
Gabriel Hu is currently offline Gabriel HuFriend
you need to use html code for that. It is called image map.
see here more details: http://www.w3schools.com/tags/tag_map.asp
Re: Active Images [message #1693275 is a reply to message #1653658] Wed, 22 April 2015 19:44 Go to previous message
Bruce MacIsaac is currently offline Bruce MacIsaacFriend
Member
You can also use external HTML editors to create image maps, and then copy and paste the HTML into EPF.
Or you can upgrade to Rational Method Composer, which has built-in area map editing.
Previous Topic:Specifying work products that appear in Work Product Breakdown
Next Topic:How can I become a committer of EPF
Current Time: Thu Dec 26 18:06:03 GMT 2024
Powered by FUDForum. Page generated in 0.04039 seconds
