Home » Modeling » GMF (Graphical Modeling Framework) » ComponentEditPolicy
ComponentEditPolicy [message #160695] Thu, 15 November 2007 09:44 Go to next message
Originally posted by: sd10046.lanet.lv
ComponentEditPolicy -> createDeleteSemanticCommand has
Command semanticCmd = getHost().getCommand(editCommandRequest);
if (semanticCmd != null && semanticCmd.canExecute()) {
CompoundCommand cc = new CompoundCommand();
cc.add(semanticCmd);
return cc;
return createDeleteViewCommand(deleteRequest);
Am I right that even if command can't be executed, view will be deleted
anyway?
Is it correct behaviour?
Ty
Re: ComponentEditPolicy [message #160933 is a reply to message #160695] Fri, 16 November 2007 08:41 Go to previous message
Ty,
Yes, your conclusion seems correct. If the logic in
shouldDeleteSemantic() is correct, then I would think that if you can't
delete the semantic element that the view should not be deleted.
However, a client may be depending on this behavior as it is now. Is it
causing you a problem?
Cherie
> return cc;
> anyway?
Previous Topic:Canvas/DiagramEditor class generation question
Next Topic:Setting of Edge bendpoints does not reflect visually
Current Time: Sun Nov 02 07:44:28 EST 2025
Powered by FUDForum. Page generated in 0.03421 seconds
