Help for creating stardust standalone engine [message #1590987] |
Thu, 29 January 2015 03:50  |
Hi all, hi support,
I tested the 2 projects found under this links:
wiki.eclipse.org/Stardust/Knowledge_Base/Testing/Standalone_Spring
wiki.eclipse.org/Stardust/KnowledgeBase/Testing/HowToTest
In the Standalone project, I ran with success the JUnit test.
Now, i would want make the steps below:
-create a standalone engine (running without tomcat server) using the libraries of stardust 2.1.0
-deploy the engine as jar file
-the engine accepts as parameter an xpdl file and entry values for the model activities
The HowToTest project accept entry values, but when i run the project, it finish with errors...
The libraries versions seem obsolete.
Is there an example of a recent project for creating a standalone project with previous steps ?
Where i can found help to do this ?
Thanks very much for your help.
Best regards
FUDForum. Page generated in 0.05784 seconds
