Adding Web library projects for tomcat [message #158317] |
Sun, 29 January 2006 10:23  |
Can somebody please help?....
I have a "utility" standard java project, which I would like deployed (put
on the classpath), along with my dynamic web project which references it,
to the tomcat 5.5 server.
According to the help what I need is to be mark my utility project as a
web library, but this only works for WebSphere® Application Server. As
both the web application and its utility project are under development at
the same time, it would be useful to make changes to the utility project
and have them picked up by the server dynamically or at least on server
restart.
My dynamic web project lists my utility project as a project references,
but this is ignored at deployment time.
I used to use sysdeo tomcat plugin and its devloader to achieve the same
functionality.
Do I need to use a web library to achieve this and if so when will it be
available in wtp for tomcat servers?
I am using Eclipse 3.1.2 and wtp 1.0 - Thanks in advance.
Re: Adding Web library projects for tomcat [message #160399 is a reply to message #160239] |
Sun, 12 February 2006 15:35  |
Thanks, I've tried it all again from scratch and now I have the Dynamic
Web Project option with wtp-sdk-M200602010238.zip.
I must have missed one archive or got it in the wrong order or something
silly.
But the good news is that I've tried the lastest M2 release build
wtp-sdk-M200602071839.zip and My dynamic web modules now work! So Im very
happy. A big thank you to the WTP team!
I would like to point out again that the documentation is
missleading\wrong\out-of-date at
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. wst.webtools.doc.user/topics/twplib.html
where it says:-
"Currently, Web Library projects are supported only when testing in the
WebSphere test environment or remotely publishing to a WebSphere®
Application Server. After these associations are made, you must restart
and republish the server for the changes to take effect"
because now with this latest M2 release I can get a web library project
published to tomcat 5.5.
Thanks again.
FUDForum. Page generated in 0.03688 seconds
