Re: two links being shown when diagrams are connected [message #160197 is a reply to message #160158] |
Wed, 14 November 2007 10:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: trommas.yahoo.com
govind wrote:
> hi all
> in my gmf project when i try to connect two diagrams it shows to links.
What do you mean by connect two diagrams. Do you mean figures? - In that
case you must specify in gmfgraph that you only want one of the links to
show graphically.
HTH,
Tomas Zijdemans
> but i want one link ..
> plz help me
> thanks
> Govind R.
Re: two links being shown when diagrams are connected [message #160394 is a reply to message #160305] |
Wed, 14 November 2007 15:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
govind wrote:
> hi..
> i need to connect figures..
> i think we need to specify in the gmfmap???
> but where exactly in that.
You should really look in the tutorial, depending on your knowledge. In
gmfgraph you specify graphical element (including links). In gmfmap you
combine the graphics with tools. Then you generate. But again, this is
all covered in the tutorial:
http://wiki.eclipse.org/GMF_Tutorial
HTH,
Tomas Zijdemans
Re: two links being shown when diagrams are connected [message #160508 is a reply to message #160394] |
Thu, 15 November 2007 05:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: govind.ashrit.xxx.com
hi..
I have gone through documentation.
Let me explain..
In my project i have many figures
for ex:
fig1,fig2,fig3,fig4 etc.
when i connect fig 1 and fig 2 it creates a single connection.
my project has feature where in i can add fig 1 and fig2 in fig3
and when i try to connect fig1 and fig2 which are now in fig3 .it shows
two connections ..
hope i am clear
Govind R.
Re: two links being shown when diagrams are connected [message #160520 is a reply to message #160508] |
Thu, 15 November 2007 06:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: biju_gopinathan.rediffmail.com
Hi Govind,
Check the following bug: this may help you
https://bugs.eclipse.org/bugs/show_bug.cgi?id=148021
Regards, Biju
govind wrote:
> hi..
> Let me explain..
> for ex:
> two connections ..
> hope i am clear
> Regards
> Govind R.
Re: two links being shown when diagrams are connected [message #160831 is a reply to message #160520] |
Fri, 16 November 2007 08:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
biju wrote:
> Hi Govind,
> Regards, Biju
> govind wrote:
>> hi..
>> Let me explain..
>> for ex:
>> two connections ..
>> hope i am clear
>> Regards
>> Govind R.
hi biju..
i gone through through that..
i couldn't get any clues...
Govind R.
Re: two links being shown when diagrams are connected [message #160864 is a reply to message #160831] |
Fri, 16 November 2007 11:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi govind,
Did you try overriding:
CanonicalEditPolicy.shouldHandleNotificationEvent()return false;
Biju
govind wrote:
> biju wrote:
>> Hi Govind,
>> Regards, Biju
>> govind wrote:
>>> hi..
>>> Let me explain..
>>> for ex:
>>> shows two connections ..
>>> hope i am clear
>>> Regards
>>> Govind R.
> hi biju..
> Regards
> Govind R.
Re: two links being shown when diagrams are connected [message #162218 is a reply to message #162104] |
Fri, 23 November 2007 09:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Govind,
Check your edit policies, and look for one edit policy which
extends CanonicalConnectionEditPolicy, (That is, The CanonicalEditPolicy
of the container of your links). And there will only be one class that
extends CanonicalConnectionEditPolicy for your digram. In that class
overwirde CanonicalEditPolicy.shouldHandleNotificationEvent(), and
return false;
It worked for me earlier, when I faced the same problem, hope
it helps you.
Cheers, Biju
govind wrote:
> hi biju
> Actually i dont have any method as shouldHandleNotificationEvent();
> or if it has to be explicitly added..
> Please help in this regard
> Regards
> Govind R
FUDForum. Page generated in 0.04645 seconds
