Home » Eclipse Projects » Oomph » Open User Dialog
Open User Dialog [message #1596419] Sun, 01 February 2015 17:10 Go to next message
Michel Parisien is currently offline Michel ParisienFriend
Did something happen to the Open User dialog? I used to peek in there to catch up on any settings I might have applied and recorded in my own user so I could update my *.setup file based on how I was actually using Eclipse. I'm guessing it was renamed and moved somewhere more hidden, but I can't find it.
Thanks.
Re: Open User Dialog [message #1596612 is a reply to message #1596419] Sun, 01 February 2015 20:22 Go to previous messageGo to next message
Michel,
There's a preference 'Oomph->Setup->Show tool bar contributions' whether
to show it as a toolbar item. We're trying to minimiye Oomph's default
visual impact given that Oomph will be in all the Mars packages by
default. Regardless of that preference, you can also use the menu
'Navigate->Open Setup->' to access the same commands as are on the toolbar.
On 01.02.2015 18:10, Michel Parisien wrote:
> Thanks.
Ed Merks
Re: Open User Dialog [message #1596618 is a reply to message #1596612] Sun, 01 February 2015 20:27 Go to previous message
Thanks Ed, you made my day. Smile
Previous Topic:Do you trust these certificates dialog during setup
Next Topic:Cannot complete a provisioning operation successfully
Current Time: Thu Dec 26 16:43:09 GMT 2024
Powered by FUDForum. Page generated in 0.02447 seconds
