Re: Want to change the filter values at run time [message #159537 is a reply to message #159448] |
Tue, 09 May 2006 11:16 |
You should be able to do this with the Design Engine API.
Take a look at:
http://www.eclipse.org/birt/phoenix/deploy/designEngineAPI.p hp
Jason
"bhaskar" <penbachi@rediffmail.com> wrote in message
news:3c80e2996178edc580a27b4b4e2cff55$1@www.eclipse.org...
> hi all,
> Iam using birt report engine to run the reports.I have deployed report
> engine in JBoss server. I want to show the default filter values and where
> clause default values in the design file to the user in the browser in
> textboxes. So user can change the values to his desire values. Now agan i
> have to set the changed values in the design. Now iam paring the deisgn
> file using DOM parser and getting the values. But this will failed if the
> design file is changed. What i want to know is,is there any birt api for
> getting the values and setting tha values from the design file.
> Please reply me ASAP.
> Thanks in advance.
> Bhaskar
Re: Want to change the filter values at run time [message #159592 is a reply to message #159568] |
Tue, 09 May 2006 12:48 |
If you download the report engine, the design engine is part of that
download.
Look at the org.eclipse.birt.report.model.api. package in modelapi.jar.
I dont have an example built that does what you want. I may be able to put
one together later in the week.
Jason
"Bhakar" <penbachi@rediffmail.com> wrote in message
news:a7c3db308ff92fe9f0adb3bef7ad0cee$1@www.eclipse.org...
> hi,
> Thanks for replay,
> Can u tell me the exact api calls for doing this. Please give the link to
> download the design engine api.
> Bhaskar
FUDForum. Page generated in 0.03265 seconds
