Home » Language IDEs » ServerTools (WTP) » Defining a server on another host
Defining a server on another host [message #159193] Mon, 06 February 2006 13:55 Go to next message
When I try to define a new server, there is a text field for the host
name. However, if I type in anything other than localhost and scan for
server types, all I get is Apache and Geronimo 1.0. If I push on a bit
further, I get a list of Tomcat versions.
Where does WTP get this list of server types from? It's not the same list
as when host=localhost.
Is it even possible to define a server that is on a host different than
your development box?
Re: Defining a server on another host [message #159455 is a reply to message #159193] Tue, 07 February 2006 13:23 Go to previous messageGo to next message
> list as when host=localhost.
I also am encountering this problem. There is a similar question posted
in eclipse.newcomer, but there is no response there either.
I would like to be able to either:
1) (preferred) Point at my Tomcat 5.5 instance on my development box.
2) or, work with the Sun App Server that already resides on my Windows
PC (localhost)
Is there now, or will there eventually be, a way to do either of these
options?
Re: Defining a server on another host [message #159478 is a reply to message #159455] Tue, 07 February 2006 15:02 Go to previous messageGo to next message
>> than your development box?
> PC (localhost)
> options?
Ok -- I found older threads that state that currently remote servers are
not supported. But there was a post (Oct 18, 2004 from Tim deBoer) that
said Servers on Mapped Network drives could be supported.
My remote Tomcat server is on a mapped drive, but I don't see how I can
set it up, because the New Server dialog wipes out the server type list
as soon as I enter a host name other than localhost.
Is there anything I can do to get Tomcat 5.5 to show up in the server
type list for my remote server?
Re: Defining a server on another host [message #159678 is a reply to message #159478] Wed, 08 February 2006 11:24 Go to previous messageGo to next message
>> PC (localhost)
>> options?
If remote servers are not supported then the UI is flawed because it
implies you can define a server for any host.
You can work with Sun's AppServer on localhost:
https://glassfishplugins.dev.java.net/specifications/introdu ction.html
I was thinking of mapping the Appserver directory on my Sun with Samba to
my Windows box running Eclipse, but I wasn't sure if WTP only manipulated
files, or if it also tried to execute commands.
Re: Defining a server on another host [message #159897 is a reply to message #159678] Thu, 09 February 2006 11:44 Go to previous messageGo to next message
>>>> host name. However, if I type in anything other than localhost and
>>>> scan for server types, all I get is Apache and Geronimo 1.0. If I
>>>> push on a bit further, I get a list of Tomcat versions.
>>> posted in eclipse.newcomer, but there is no response there either.
>>> Windows PC (localhost)
>>> these options?
>> are not supported. But there was a post (Oct 18, 2004 from Tim
>> deBoer) that said Servers on Mapped Network drives could be supported.
>> can set it up, because the New Server dialog wipes out the server type
>> list as soon as I enter a host name other than localhost.
> to my Windows box running Eclipse, but I wasn't sure if WTP only
> manipulated files, or if it also tried to execute commands.
Hey Eric,
Thanks for the glassfish link. That will be a big help.
Re: Defining a server on another host [message #160247 is a reply to message #159478] Fri, 10 February 2006 14:25 Go to previous message
Bug 111421 indicates that remote server support is possible, but it
depends on the server adapter itself to implement it.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=111421
- Nitin
Previous Topic:WPT on Linux located in custom 'extension' directory
Next Topic:Problem with webtools plugin
Current Time: Wed Apr 16 01:21:06 EDT 2025
Powered by FUDForum. Page generated in 0.03925 seconds
