Home » Language IDEs » Java Development Tools (JDT) » moving packages recursively - is it possible?
moving packages recursively - is it possible? [message #157305] Wed, 05 May 2004 05:48 Go to next message
I have not found the way to move package with subpackages
recursively. For example, there are packages:
a.b
a.c.d.e
a.c.d.f
And this result is needed:
a.b.d.e
a.b.d.f
a.c
i.e., to move d package with subpackages d.e and d.f from a.c
package into a.b package. Have I missed something?
I'm using 20040428 integration build.
Andrew
Re: moving packages recursively - is it possible? [message #158563 is a reply to message #157305] Thu, 13 May 2004 09:24 Go to previous messageGo to next message
Originally posted by: john.childress.entergykoch.com
I was looking for the same functionality. Coming from IntelliJ I had
this... Am I missing the obvious?
thanks,
John
"Andrew Gaydenko" <a@etver.com> wrote in message
news:c7ada5$irh$1@eclipse.org...
> a.b
> a.c.d.e
> a.c.d.f
> a.b.d.e
> a.b.d.f
> a.c
> Andrew
Re: moving packages recursively - is it possible? [message #158583 is a reply to message #157305] Thu, 13 May 2004 11:11 Go to previous messageGo to next message
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Andrew,
Maybe I don't understand what you mean, but if I do I think you can do
it by switching to Hierarchical view in the Package Explorer. That way,
the packages will be shown as a tree and you should be able to select
the d package (with all its contents).
Jesper
> a.b
> a.c.d.e
> a.c.d.f
> a.b.d.e
> a.b.d.f
> a.c
> Andrew
Re: moving packages recursively - is it possible? [message #158592 is a reply to message #158583] Thu, 13 May 2004 11:29 Go to previous messageGo to next message
Sure,
but when I rename that package, the child packages are still under the
original name.
com.test
com.test.test1
com.test.test1.test2
com.test.test1.test3
I want to rename com.test.test1 to com.test.fun and have both test2 and
test3 now be under com.test.fun
Clear or not really?
thanks,
John
"Jesper Kamstrup Linnet" <linnet@nospam.users.sourceforge.net> wrote in
message news:c802qv$un5$1@eclipse.org...
> Hi Andrew,
> Best regards,
> Jesper
> > a.b
> > a.c.d.e
> > a.c.d.f
> > a.b.d.e
> > a.b.d.f
> > a.c
> > Andrew
Re: moving packages recursively - is it possible? [message #158670 is a reply to message #157305] Thu, 13 May 2004 16:45 Go to previous message
yes, bugzilla :)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=39260
a.
Previous Topic:Configuration problems
Next Topic:refactoring inspires net activity
Current Time: Fri Nov 07 21:31:09 EST 2025
Powered by FUDForum. Page generated in 0.03884 seconds
