Home » Modeling » GMF (Graphical Modeling Framework) » how to recover all information from the diagram
how to recover all information from the diagram [message #156841] Tue, 23 October 2007 12:01 Go to next message
Originally posted by: giuseppeloprete.gmail.com
Hi all, I have a problem: I create, for example, 3 node in file
"*.example_diagram" (with my editor) that I call A,B,C
I draw a connection from A to B. If I go in the related xml "*.example" I
find this:
<connection name="conn_1"/>
<source name="A"/>
<target name="B"/>
</connection>
And this is correct. Then, I create a new connection from B to C. I go in
the xml and I find this structure:
<source name="A"/>
</connection>
<connection name="conn_2"/>
<source name="B"/>
<target name="C"/>
</connection>
So, I lost information about the first connection and I don't know how to
get it. The "*.example" isn't correct, the "*.example_diagram" is correct.
But I need to work on the xml file and not on the diagram.
Pleas help me, I'm blocked with my thesis.
Re: how to recover all information from the diagram [message #157246 is a reply to message #156841] Fri, 26 October 2007 10:15 Go to previous message
problem solved, if you have the same error check the ecore connections
Previous Topic:cascade delete in emf/gmf
Next Topic:node' name
Current Time: Sun Nov 02 09:26:13 EST 2025
Powered by FUDForum. Page generated in 0.35165 seconds
