WST is dead after out of memory exception [message #156191] |
Thu, 12 January 2006 18:01 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: parwen777.yahoo.se
I tried to create a new EJB project and got an error. After that it is
impossible to create anything from the J2EE perspective. I keep getting
NPEs. Have downloaded the maintenance release, but its the same. I got an
java.lang.OutOfMemoryError: PermGen space
and after that I get
!ENTRY org.eclipse.ui 4 0 2006-01-12 18:12:07.508
!MESSAGE java.lang.NullPointerException
!STACK 0
at
org.eclipse.jst.server.core.internal.RuntimeBridge$Stub.getR untimeComponents(RuntimeBridge.java:153
!ENTRY org.eclipse.wst.sse.core 4 4 2006-01-12 18:01:13.145
!MESSAGE Program Error: invalid structured document event
!ENTRY org.eclipse.ui 4 4 2006-01-12 18:01:13.160
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-01-12 18:01:13.160
!STACK 0
java.lang.RuntimeException: java.lang.NullPointerException
at
org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment.replaceText(JobSafeStructuredDocument.java:113)
at
org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.replaceText(BasicStructuredDocument.java:2331)
at
org.eclipse.wst.sse.ui.internal.StructuredDocumentToTextAdap ter.replaceTextRange(StructuredDocumentToTextAdapter.java:11 87)
at org.eclipse.swt.custom.StyledText.modifyContent(StyledText.j ava:5787)
at org.eclipse.swt.custom.StyledText.sendKeyEvent(StyledText.ja va:6625)
at org.eclipse.swt.custom.StyledText.doBackspace(StyledText.jav a:2524)
at org.eclipse.swt.custom.StyledText.invokeAction(StyledText.ja va:5668)
at org.eclipse.swt.custom.StyledText.handleKey(StyledText.java: 5102)
at org.eclipse.swt.custom.StyledText.handleKeyDown(StyledText.j ava:5124)
at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.j ava:4857)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:880)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:876)
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1190)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3135)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3038 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
at
org.eclipse.jface.text.DefaultPositionUpdater.update(Default PositionUpdater.java:227)
at
org.eclipse.wst.sse.core.internal.text.GenericPositionManage r.updatePositions(GenericPositionManager.java:395)
at
org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.updateDocumentData(BasicStructuredDocument.java:2602)
at
org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.reparse(StructuredDocumentReParser.java:1350)
at
org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.reparse(StructuredDocumentReParser.java:1305)
at
org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.checkForQuotes(StructuredDocumentReParser.java:650)
at
org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.checkForCrossStructuredDocumentRegionSyntax(Structured DocumentReParser.java:554)
at
org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.checkForCrossStructuredDocumentRegionBoundryCases(Stru cturedDocumentReParser.java:527)
at
org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.checkHeuristics(StructuredDocumentReParser.java:665)
at
org.eclipse.wst.sse.core.internal.text.StructuredDocumentReP arser.reparse(StructuredDocumentReParser.java:1281)
at
org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.updateModel(BasicStructuredDocument.java:2614)
at
org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.internalReplaceText(BasicStructuredDocument.java:1867)
at
org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.replaceText(BasicStructuredDocument.java:2335)
at
org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment.access$0(JobSafeStructuredDocument.java:1)
at
org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment$1.run(JobSafeStructuredDocument.java:95)
at
org.eclipse.wst.sse.ui.EditorExecutionContext.execute(Editor ExecutionContext.java:42)
at
org.eclipse.wst.sse.core.internal.text.JobSafeStructuredDocu ment.replaceText(JobSafeStructuredDocument.java:105)
... 38 more
!ENTRY org.eclipse.ui 4 4 2006-01-12 18:01:13.176
!ENTRY org.eclipse.ui 4 0 2006-01-12 18:01:13.176
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at
at
at
at
at
at
at
org.eclipse.wst.sse.core.internal.text.GenericPositionManage r.computeIndexInPositionList(GenericPositionManager.java:189 )
at
org.eclipse.wst.sse.core.internal.text.GenericPositionManage r.addPosition(GenericPositionManager.java:89)
at
org.eclipse.wst.sse.core.internal.text.GenericPositionManage r.addPosition(GenericPositionManager.java:66)
at
org.eclipse.wst.sse.core.internal.text.BasicStructuredDocume nt.addPosition(BasicStructuredDocument.java:842)
at
org.eclipse.ui.texteditor.AbstractTextEditor$9.run(AbstractT extEditor.java:498)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
!ENTRY org.eclipse.ui 4 4 2006-01-12 18:08:42.804
!ENTRY org.eclipse.ui 4 0 2006-01-12 18:08:42.819
!MESSAGE java.lang.OutOfMemoryError: PermGen space
!STACK 0
java.lang.RuntimeException: java.lang.OutOfMemoryError: PermGen space
at
org.eclipse.wst.common.project.facet.ui.AddRemoveFacetsWizar d.performFinish(AddRemoveFacetsWizard.java:325)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at
org.eclipse.wst.common.navigator.internal.actions.WizardShor tcutAction.run(WizardShortcutAction.java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at
at
at
at
at
at
Caused by: java.lang.OutOfMemoryError: PermGen space
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2006-01-12
18:08:45.757
!MESSAGE One or more constraints have not been satisfied.
!SUBENTRY 1 org.eclipse.wst.common.project.facet.core 4 0 2006-01-12
18:08:45.757
!MESSAGE Cannot install project facet Java 5.0. Some version of this
project facet is already installed.
!ENTRY System Bundle 0 0 2006-01-12 18:09:18.929
!MESSAGE FrameworkEvent.ERROR
!STACK 0
!ENTRY update@plugins/org.eclipse.update.core_3.1.1.jar 0 0 2006-01-12
18:09:23.38
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.update.internal.core.UpdateCore.stop() of bundle
org.eclipse.update.core.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1051)
at
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:394)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:510)
at
org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1054)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:620)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:283)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:256)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:190)
at
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:536)
at
org.eclipse.osgi.framework.internal.core.SystemBundle$1.run( SystemBundle.java:171)
at java.lang.Thread.run(Thread.java:595)
Root exception:
!ENTRY update@plugins/org.eclipse.team.cvs.ssh2_3.1.0/ 0 0 2006-01-12
18:09:26.585
!STACK 0
org.eclipse.team.internal.ccvs.ssh2.CVSSSH2Plugin.stop() of bundle
org.eclipse.team.cvs.ssh2.
at
at
at
at
at
at
at
at
at
at
Root exception:
!ENTRY update@plugins/org.eclipse.team.core_3.1.1.jar 0 0 2006-01-12
18:09:28.679
!STACK 0
org.eclipse.team.internal.core.TeamPlugin.stop() of bundle
org.eclipse.team.core.
at
at
at
at
at
at
at
at
at
at
Root exception:
!ENTRY update@plugins/org.eclipse.pde.core_3.1.1.jar 0 0 2006-01-12
18:09:33.382
!STACK 0
org.eclipse.pde.internal.core.PDECore.stop() of bundle
org.eclipse.pde.core.
at
at
at
at
at
at
at
at
at
at
Root exception:
!ENTRY update@plugins/org.eclipse.jdt.launching_3.1.0.jar 0 0 !SESSION
2006-01-12 18:09:27.163 -----------------------------------------------
eclipse.buildId=M20050929-0840
java.version=1.5.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sv_SE
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 2 1 2006-01-12 18:12:07.383
!MESSAGE NLS missing message: NewEJBModuleAction_UI_0 in: ejb_ui
!ENTRY org.eclipse.ui 4 4 2006-01-12 18:12:07.508
!STACK 0
at
org.eclipse.jst.server.core.internal.RuntimeBridge$Stub.getR untimeComponents(RuntimeBridge.java:153)
at
org.eclipse.wst.common.project.facet.core.runtime.internal.B ridgedRuntime.supports(BridgedRuntime.java:68)
at
org.eclipse.wst.common.project.facet.core.runtime.internal.A bstractRuntime.supports(AbstractRuntime.java:87)
at
org.eclipse.wst.common.componentcore.datamodel.FacetProjectC reationDataModelProvider.getValidPropertyDescriptors(FacetPr ojectCreationDataModelProvider.java:228)
at
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elImpl.getValidPropertyDescriptors(DataModelImpl.java:320)
at
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper.setWidgetValue(DataModelSynchHelper.java:29 8)
at
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper$1.run(DataModelSynchHelper.java:221)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:152)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:28)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:3413)
at
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper.synchUIWithModel(DataModelSynchHelper.java: 212)
at
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper.synchComposite(DataModelSynchHelper.java:43 5)
at
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelSynchHelper.synchCombo(DataModelSynchHelper.java:472)
at
org.eclipse.wst.web.ui.internal.wizards.DataModelFacetCreati onWizardPage.createServerTargetComposite(DataModelFacetCreat ionWizardPage.java:102)
at
org.eclipse.jst.j2ee.internal.wizard.J2EEComponentFacetCreat ionWizardPage.createTopLevelComposite(J2EEComponentFacetCrea tionWizardPage.java:47)
at
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizardPage.createControl(DataModelWizardPage.java:101)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:179)
at
org.eclipse.wst.common.project.facet.ui.AddRemoveFacetsWizar d.createPageControls(AddRemoveFacetsWizard.java:256)
at
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:611)
at
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:502)
at org.eclipse.jface.window.Window.create(Window.java:418)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:996)
at
org.eclipse.wst.common.navigator.internal.actions.WizardShor tcutAction.run(WizardShortcutAction.java:112)
at
at
at
at
at
at
at
at
at
Re: WST is dead after out of memory exception [message #156210 is a reply to message #156191] |
Thu, 12 January 2006 19:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: caclark.etechsolutions.net
You have any parameters in your eclipse.ini like these?
-vmargs
-Xms256m
-Xmx768m
-XX:MaxPermSize=128m
-Dcom.sun.management.jmxremote
Palle said the following on 1/12/2006 12:01 PM:
> !STACK 0
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 38 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 18:08:45.757
> 18:08:45.757
> !STACK 0
> 18:09:23.38
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Root exception:
> 18:09:26.585
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Root exception:
> 18:09:28.679
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Root exception:
> 18:09:33.382
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Root exception:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03645 seconds
