How can I do a node non movable? [message #155302] |
Mon, 15 October 2007 11:39 |
Originally posted by: ijerez2001.gmail.com
Hello all,
I try to do a node that it cannot move because a I implement the location
for this.
I have seen another post that ask for this problem but it is not answered.
Thanks.
Re: How can I do a node non movable? [message #155544 is a reply to message #155302] |
Tue, 16 October 2007 08:58 |
Originally posted by: jan.herriger.gmx.de
you could override the LayoutEditPolicy in your DiagramEditPart like this:
installEditPolicy(EditPolicy.LAYOUT_ROLE, new XYLayoutEditPolicy(){
protected Command getMoveChildrenCommand(Request request) {
boolean containsUnmoveable = false;
for(Object o : ((ChangeBoundsRequest)request).getEditParts())
if (o instanceof MyUnmoveableEditPart)
containsUnmoveable = true;
break;
return containsUnmoveable?UnexecutableCommand.INSTANCE:
getResizeChildrenCommand((ChangeBoundsRequest)request);
Iván Jerez schrieb:
> Hello all,
> location for this.
> Thanks.
Re: How can I do a node non movable? [message #155595 is a reply to message #155544] |
Tue, 16 October 2007 10:58 |
It work perfect!
Thank you very much
"Jan Herriger" <jan.herriger@gmx.de> escribió en el mensaje de
noticias:ff1ues$n18$1@build.eclipse.org...
> boolean containsUnmoveable = false; for(Object o :
> break;
> Iván Jerez schrieb:
>> Hello all,
>> for this.
>> answered.
>> Thanks.
Re: How can I do a node non movable? [message #155625 is a reply to message #155595] |
Tue, 16 October 2007 11:12 |
Oh... wait a minute.
In your EditPart, you should find a methos like this:
public EditPolicy getPrimaryDragEditPolicy() {
EditPolicy result = super.getPrimaryDragEditPolicy();
if (result instanceof ResizableEditPolicy) {
ResizableEditPolicy ep = (ResizableEditPolicy) result;
ep.setResizeDirections(PositionConstants.NONE);
//dont't move me
ep.setDragAllowed(false);
return result;
Adding the line under the comment should be prefered, I think. So, you
don't have to override DiagramEditPart's LayoutEditPolicy.
Iván Jerez schrieb:
> It work perfect!
> Thank you very much
>> Hi,
>> this:
>> break;
>> Iván Jerez schrieb:
>>> Hello all,
>>> location for this.
>>> answered.
>>> Thanks.
Re: How can I do a node non movable? [message #155675 is a reply to message #155625] |
Tue, 16 October 2007 11:20 |
Yes, I add this piece of code:
break;
to the method createLayoutEditPolicy(), that it contained one.
Thanks again.
noticias:ff26b2$no4$1@build.eclipse.org...
> //dont't move me
> return result;
> Iván Jerez schrieb:
>> It work perfect!
>> Thank you very much
>>> Hi,
>>> this:
>>> break;
>>> Iván Jerez schrieb:
>>>> Hello all,
>>>> location for this.
>>>> answered.
>>>> Thanks.
Re: How can I do a node non movable? [message #164882 is a reply to message #155625] |
Mon, 10 December 2007 12:27 |
> //dont't move me
> return result;
I've implemented this method in the EditPart of a Node. It works, but my
problem is that the figure overlaps existing figures. The running the
setLocation method yields no effect.
How can I solve this?
Best Regards,
Tomas Zijdemans
FUDForum. Page generated in 0.03014 seconds
