Home » Eclipse Projects » GEF » Command.execute will not be called
Command.execute will not be called [message #155309] Sat, 23 October 2004 21:15 Go to next message
Andreas Herz is currently offline Andreas HerzFriend
I have installed the key handler for the DEL Command of an EditPArt in GEF...
.....the delete of objects has be worked fine - but after some code changes the
MyDeleteCommand.execute() will not be called!!
If I select an EditPart (Figure) in the GEF the "call history" of my programm
looks like:
(the root edit part) 1. > FormElementEditPart.getDragTracker
(my edit policy) 2. > ComponentEditPolicyForwardDelete.getDeleteCommand
3. > GroupComponentEditPolicy.createDeleteCommand
4. > ComponentEditPolicyForwardDelete.getParentDeleteCommand
5. > XYLayoutEditPolicyFormImpl.getDeleteDependantCommand
(delete of the slec. object)6. > DeleteGroupCommand.DeleteGroupCommand
7. > XYLayoutEditPolicyGroupImpl.getDeleteDependantCommand
8. > DeleteGroupCommand.DeleteGroupCommand
I can see, that the right delete command has been created.
But the execute method will not be called if i press the DEL
key.
Greetings
Andreas
Re: Command.execute will not be called [message #155778 is a reply to message #155309] Tue, 26 October 2004 21:19 Go to previous message
Pratik Shah is currently offline Pratik ShahFriend
If you have a global DeleteAction registered, you don't need the KeyHandler
to do this.
Regarding this problem, does the CompoundCommand's canExecute() method
return true?
"FreeGroup" <a.herz@FreeGroup.de> wrote in message
news:cleh46$adj$1@eclipse.org...
GEF...
the
programm
> looks like:
> 3. >
> 4. >
> 5. >
> 7. >
> key.
> Greetings
> Andreas
Previous Topic:Connection behind node
Next Topic:A Question Regarding UpdateManager
Current Time: Wed Feb 05 16:01:01 GMT 2025
Powered by FUDForum. Page generated in 0.02930 seconds
